Author Topic: CBN Cup Wheel  (Read 1686 times)
Offline Alston
CBN Cup Wheel
« on: July 25, 2024, 10:33:49 AM »
Have any of you been able to source a CBN cup wheel like this at a good price. As you can see, the one in the picture doesn’t inspire confidence as it surely can’t be both Diamond AND CBN?!
Offline pirmin
Re: CBN Cup Wheel
« Reply #1 on: July 26, 2024, 01:31:16 AM »
they probably want to say that the diamonds are cbn particles ( cbn are basicly also cristaline structures), Cubic Boron Nitride.
I recently worked with the vevor drill grinder and it had a suprisingly good cbn wheel. i personaly only use resin bound cbn on my d bit grinder but the chinese stuff wasnt that bad !
Offline Alston
Re: CBN Cup Wheel
« Reply #2 on: July 26, 2024, 10:44:47 PM »
I’ve been led to believe that the electroplated wheels last longer than the resin ones. I know several wood turners that use 6” and 8” CBN wheels and have reported no noticeable wear after several years use.
Offline pirmin
Re: CBN Cup Wheel
« Reply #3 on: July 27, 2024, 10:19:35 AM »
Well, once an electroplated wheel is worn out, it's finished.
A resin-bound wheel, on the other hand, can be redressed quite easily. I personally use a white aluminum oxide stone (these are marketed as dressing stones by Norton Abrasives and Tyrolit Grinding). You manually feed the stone into the wheel until it's cleaned up. After this treatment, the wheel cuts as it should. I've observed that many people using abrasive grinding wheels find them clogged with soft steels and other materials, such as the residue from marking with Sharpies, which severely clogs the wheel.
I personally prefer resin-bound wheels, but the choice also depends on whether it's for roughing or fine grinding. The wheel mentioned earlier is still a very coarse one.
