Author Topic: another option for the oil pump  (Read 10046 times)
« on: July 24, 2024, 10:32:40 AM »
Some time ago I discovered this drawing of an oil pump at the flea market. You can see a way of pumping oil that I don't know about.
Unfortunately there is no information about what this oil pump is used for. But I find the mechanism interesting. A completely different construction of oil pumps.
(The handwriting is old German script. Not easy to read. Appears to be from January 11th, 1892. It is not a print but drawn with ink.)
Re: another option for the oil pump
« Reply #1 on: July 24, 2024, 01:35:38 PM »
Basically a ratchet driven pump. The lever is connected by a link to the cross head of an engine. As it oscillates it moves the arm with the pawl and this in turn rotates the toothed wheel which has a Scotch yoke connection to the pump shaft.  The amount of feed is controlled by the position of the link rod hooked to the pawl arm.
A lot of steam traction engines use this type of pump but the pump assembly is inside a box full of oil.
« Reply #2 on: July 24, 2024, 01:51:14 PM »
Yes, the drive is like all oil pumps. I think the changeover valve is unusual, but necessary in this case.
Online Jasonb
« Reply #3 on: July 24, 2024, 02:22:37 PM »
Yes as you say the valve is unusual and would only allow a set amount of oil into the pump chamber per stroke. Looks like there may be some adjustment of how long the valve is open by moving the pawls
The usual ratchet type found on traction engines etc just have the pump chamber open to the oil resovoir which completely fills it as the piston withdraws.
« Reply #4 on: July 24, 2024, 02:48:49 PM »
I think that direction control (changeover) valve arrangement is very clever.  :thinking:
Offline Charles Lamont
« Reply #5 on: July 24, 2024, 08:17:48 PM »
It looks as though the pump stroke can be altered at the scotch crank. The 'flipping' plug valve is different. First I have seen a mechanical lubricator with any form of mechanically operated valve. The drawing does not show the usual second pawl pivoted on the frame to prevent the ratched wheel from turning backwards. I don't see why the oil passages are so small. Did the designer think the oil was thixotropic?!
