Author Topic: Semi-rotatry valve wood/PVC air engine  (Read 2279 times)
Offline dudeface
  • Dodge Co., WI
    • LVE Forum
« on: June 24, 2024, 12:32:46 AM »
I found a broken garden tool handle that fits nicely inside some PVC pipe I have, so naturally it had to become an engine. I came up with this simple design. The wood handle will be the piston and valve, the latter having offset ports in it for intake and exhaust and being perpendicular to the cylinder, pivoting back and forth via a connecting rod. Here's a couple quick sketches and photos.
Photo A: the piston is all that's currently anywhere close to being done.
Photo B: I'll make the connecting rods from this old hacksaw blade.
Photo C: The fit of the piston inside the PVC pipe.
The crankshaft will be bent out of some thick wire.
Miles
It's almost like the faster I spin it, the more times it goes around.....
Re: Semi-rotatry valve wood/PVC air engine
« Reply #1 on: June 24, 2024, 12:41:42 AM »
The Robinson Crusoe engine, made from stuff washed up on the desert island! Slick!
Offline MJM460
« Reply #2 on: June 24, 2024, 12:02:53 PM »
That’s real creative thinking Miles.  Quite a change from your Lego engines.  P looking forward to watching your progress.  Please keep us posted.
