Author Topic: Borderer Piston valve version  (Read 37532 times)
Offline Team ricky
Re: Borderer Piston valve version
« Reply #60 on: August 12, 2024, 11:19:53 pm »
Managed to finish the second rod today and one cross head ;)
Quite good parts with a fair bit going on !
I’ve made up a solution of Nickel and I’ll plate the rods and another engines crank !
Offline Team ricky
« Reply #61 on: August 13, 2024, 05:53:22 pm »
On to Nickel plating today so a bit more chilled 😎
I’ll post a pic once the first rod is plated ….
One thing I did notice and thought about was oil ways for the big end , I don’t know what the intended oiling method is needed as per drawing as there are no holes for the oil to get fully into the bearings… I’m thinking just splashing a bit around the big end and crank isn’t really going to oil the contact surfaces!? Or maybe I’m overthinking and the oil will get in there ! Not sure Tbh
« Reply #62 on: August 13, 2024, 06:09:29 pm »
Some of mine I put in oil holes, some I just put drops down in next to the crank pin and the web. For occasional demo running thats plenty.
Offline Team ricky
« Reply #63 on: August 13, 2024, 11:31:43 pm »
I guess oil will capillary action it way in ;)
Here’s the con rods plated , Came out pretty good and should hold back surface rust
« Reply #64 on: August 13, 2024, 11:51:23 pm »
Be aware that nickle plating will tarnish, but at least not rust. When car parts are chromed, the color is actually a nickle plating, then its topped with a chrome layer that is basically transparent, but is shinier and prevents the tarnishing.
Nice results!!
Offline Team ricky
« Reply #65 on: August 16, 2024, 06:24:20 pm »
Thanks for the heads up ;)
Here’s a little more complete!
Two pistons and one rod, pretty standard stuff but took care to get a close fit and a good ring groove !
I went with Vitron o rings mainly due to having good wear properties and heat resistance is good too , I’ll make the second rod and lower cylinder cover glands - after that lot I’ve pretty much got an engine
One problem I have caught is I had made the lower features of the cross head upside down after I had drilled the fixing hole (M3)
So to re- establish that hole on the other side concentric I have ordered the correct ER20 collet , If that fails I’ll make a new one , hopefully won’t need to tho and learning rescue methods is a good thing ;)
Offline Team ricky
« Reply #66 on: August 25, 2024, 12:46:01 pm »
Starting to feel like an engine now ;) I have finished the cross heads and pins and installed the rods and trunks to test!
All spinning over very well indeed
Offline Team ricky
« Reply #67 on: August 25, 2024, 12:46:50 pm »
Side on
Offline Team ricky
« Reply #68 on: August 30, 2024, 10:48:17 pm »
I made the flywheel and tidied the piston valve housings ;)
Also made and fitted the cylinder trunk gaskets and final fit for those too, A little blue locktite on the screws and span everything over and alls good !
The flywheel is a friction fit and a slip fit if i slightly warm it which is perfect, I’ll use a set screw but that won’t misalign anything as it’s such a close fit ……
Weight wise 1600grams at the mo
« Reply #69 on: August 30, 2024, 11:06:00 pm »
Your engine is really coming along!   :popcorn: :ThumbsUp:
Offline stevendavis
« Reply #70 on: August 31, 2024, 04:07:44 pm »
Really nice work so far!
If you want to see my super power, pull my finger!
Offline Team ricky
« Reply #71 on: September 02, 2024, 11:58:22 pm »
Cheers chaps ;)
I’ve really enjoyed my first engine !!
I think I’m going to start a cast iron version of the Borderer, I like the design and the looks and with care they can look very tidy indeed!
So the plan will be all parts made not cast , Block , valve chests covers, trunks, cylinder covers, base all cast iron , Then mild steel for rods, crank, eccentric
I guess bronze pistons and stainless rods
Bronze cross heads and bearings
Should look a bit more scale in cast iron and wood cladding ;)
Oh and slide valve for this one as it won’t be fitted to a boat just on display
Offline Team ricky
« Reply #72 on: May 27, 2025, 08:09:06 pm »
Here’s a bit more done on this project :)
I’ve made the eccentric components fully, bored the piston valve housings, made the piston valve fork ends ….
Not too much to go now !
After having problems with the marcher piston valves I have made absolutely sure I’m within 2 microns tolerance between the valve and housing… not easy but well worth it , For a test if you put sharpie on the valve stock it almost jams up trying to slide from the un-sharpied section ….. Seriously happy with that and the engine should make good power :)
Offline Team ricky
« Reply #73 on: June 20, 2025, 03:12:15 pm »
Well here we are :)
First run just using a quick and dirty fitting into one cylinder only ….
It has very strong beats indeed for a piston valve engine!
I’ll set up the other cylinder timing in the same way then make all the pipe work
Jobs to finish are cladding, pipes , reverse valve ….. hopefully by the end of the weekend I may be finished
Video below in link
« Last Edit: June 20, 2025, 04:39:52 pm by Team ricky »
Offline Team ricky
« Reply #74 on: June 20, 2025, 03:12:55 pm »
A pic :)
