Author Topic: Marcher twin cylinder marine steam  (Read 21736 times)
Offline Team ricky
Re: Marcher twin cylinder marine steam
« Reply #60 on: September 30, 2024, 01:24:40 PM »
Hi Per,
Yes one day ! I’ve got a mahogany rc boat to finish first, I get side tracked pretty easily!
I think I will set up a base to run it on for now and display :)
Offline Team ricky
« Reply #61 on: September 30, 2024, 03:44:42 PM »
A little vid of the engine reversing and on 14psi air !
Please excuse the Gregious noise !!
« Reply #62 on: September 30, 2024, 07:04:00 PM »
That is certainly moving - but at the most likely Propsize, that is also needed  ;)
Per   :cheers:
Offline Team ricky
« Reply #63 on: October 01, 2024, 12:37:45 AM »
To be fair to the engine it is now making some power !
You can’t easily stop the engine via the 1/4” shaft in either direction….
I’ll check it on steam and see if it will run at say 10psi and if it’s got good power at 45psi I may call it and crack on with the bigger version ;) of course making good valves again will be key
Offline Team ricky
« Reply #64 on: October 11, 2024, 02:05:12 PM »
Here’s a short video of the boiler I have made for this size of engine ;)
The boiler is good as a test boiler and can be later fitted to a boat of around 36-42”
I will photograph the finishing to include lagging, better burner, wood cladding and flue
Offline Team ricky
« Reply #65 on: October 11, 2024, 03:01:58 PM »
Couple of pics ;)
Offline Team ricky
« Reply #66 on: October 11, 2024, 03:42:57 PM »
I had forgotten some what that i designed the boiler to share the top Flue/register with another model !
Reason being it was a success and simple , just two M3 nuts and you’re good to go ! Access dead easy…
The wood I may go with is Cheery for a change, It slips under the flue nicely
Offline Team ricky
« Reply #67 on: October 12, 2024, 12:41:06 PM »
I had forgotten that I went with mahogany for the engine so I had brought more for the boiler a while back ;)
Fitted nicely! Just need some boiler banding material. The plant weighs 2.4kg and would be great on RC
Offline Team ricky
« Reply #68 on: October 14, 2024, 04:13:28 PM »
I did a quick steam test just to see how good or bad the valves make the engine run !
Safe to say luckily it runs super ! You can now hear the beat of the steam clearly in each stroke and not just the bypass hissing sound you typically hear with piston valves , Im happy to leave it there and set up on a little display board and enjoy seeing and hearing it run slow …. It also ran on low pressure too so all good there
Offline Team ricky
« Reply #69 on: October 14, 2024, 04:13:52 PM »
Another clip
« Reply #70 on: October 14, 2024, 04:22:37 PM »
Superb!!
« Reply #71 on: October 14, 2024, 05:32:49 PM »
Good run. :ThumbsUp:
« Reply #72 on: October 14, 2024, 06:33:13 PM »
Runs very well  :ThumbsUp:
Per     :cheers:
Offline Team ricky
« Reply #73 on: October 16, 2024, 06:53:26 PM »
Thanks chaps ;)
I’ve enjoyed this one ☝️
Here’s a short video of the boiler in operation !
All went well and I used my mk1 puffin to test , it makes plenty of steam just on 1/2 - 3/4 gas tap open, relief valve set to 60psi as the hydraulic test was at 120psi
Last job is to bolt down the boiler to its base and engine, I will probably pair these together as you see them as for RC use the oscillator engine is a fair bit more powerful and uses less steam …..
Offline Team ricky
« Reply #74 on: October 16, 2024, 06:55:39 PM »
A slightly better clip ;)
