Author Topic: 1/4” Union cones in USA  (Read 7289 times)
Offline Andyreww
« on: March 26, 2024, 02:47:29 pm »
Hi All,
Sorry if this is in the wrong forum. I’m looking for a supplier of 1/4” union cones (solder nipples) in the USA. PM Research has sizes but not 1/4”. I’ve searched around a lot and can’t find any - maybe named differently. I could make them but would prefer to buy if possible.
Appreciate any help…
Andy
Re: 1/4” Union cones in USA
« Reply #1 on: March 26, 2024, 03:09:55 pm »
Smaller solder on ones (up to 4mm) are out there, but only things I've seen for 1/4" and above are the slip on compression fitting rings, which could always be soldered in place.
« Reply #2 on: March 26, 2024, 04:09:56 pm »
Same here.  I've only seen the olives for compression type fittings, not the solder on nipples for sale.
Hope you can find them!
« Reply #3 on: March 26, 2024, 07:15:18 pm »
These items were discussed several years ago on another forum. Most people said they made their own or had a friend with a lathe make some. But I recall there was a New York City firm mentioned that specialized in repairing coffee and espresso machines that had them. Might be worth a google search using "espresso pipe nipples soldered" or something like that. Good luck!  :cheers:
(If you cant find any, I do know there are a few places in UK you can get them, original purpose for old car repairs. MG used them on some cars. But shipping may be costly from UK)
« Reply #4 on: March 26, 2024, 07:31:52 pm »
Plenty of the UK model engineering suppliers do them either called nipples or ferrules. We us ehem a lot more than the US which likes it's threaded pipe and fittings. Which may be why they are available stateside under 4mm as the threaded fittings start at 3/16
If it is just a few you need they are not hard to make.
Offline Andyreww
« Reply #5 on: March 26, 2024, 07:37:07 pm »
Thanks for this, yes, a lot of suppliers in the UK, may have to pay shipping unfortunately. I will take a look at coffee machine parts though - thank-you!
