Author Topic: Clamping shaft for a feeler gauge.  (Read 3290 times)
Offline Bruno Mueller
    • My Homepage
« on: February 22, 2024, 12:23:42 PM »
A few years ago, I was given a Swiss feeler gauge as a gift. The data output of the mechanical clock was cut off. At that time I had attached a holder with a Ø 4 mm pin, which only allowed the gauge to be clamped.
The dovetail had an unusual dimension.
I ground a dovetail cutter from a Ø 4 mm graver blank. The narrowest point of the cutter is just 2 mm in diameter.
I milled a 3 mm groove 2.5 mm deep into a piece of Ø 8 mm round bar and then milled the dovetail in tenths of a millimetre with the graver I had made. In between, I checked from time to time how the dial gauge fitted.
The shaft was drilled through with 4.1 mm and an M 6 thread was cut approx. 15 deep at the end.  A piece of the graver material (4 mm HSS turning steel) was cut off and ground flat on the graver grinding machine. This serves as a pressure piece for fastening.
http://mueller-bruno.de/  http://www.bosch-combi.de/   https://www.youtube.com/@Jailguzzi
Whoever talks shit about me behind my back is in the best position to lick my ass.
Greetings from the southwest of Germany.
Offline gerritv
  • St Catharines, ON
Re: Clamping shaft for a feeler gauge.
« Reply #1 on: February 22, 2024, 01:43:32 PM »
A very clean solution to the clamping, hadn't seen it done that way before.
gerrit
