Yes I took it a sAluminium at both ends, and agree that too snug a fit may cause problems with expansion and depending on the amount of use galvanic attack could be an issue.But regarding heat the plates are a bit like the 648 will they see direct heat ?and if so what flame temperature and more importantly material temp, a typical air/propane torch may only give 750degC temp in the components and that is with the flame directly applied
Quote from: Jasonb on February 22, 2024, 07:32:06 pmYes I took it a sAluminium at both ends, and agree that too snug a fit may cause problems with expansion and depending on the amount of use galvanic attack could be an issue.But regarding heat the plates are a bit like the 648 will they see direct heat ?and if so what flame temperature and more importantly material temp, a typical air/propane torch may only give 750degC temp in the components and that is with the flame directly appliedYou need to be careful how you interpret that graph. That graph shows the flame temperature of propane/ air to be 1950*C and that has only recently been demonstrated to be hot enough to melt pure copper down tubes. It appears that the flame tube (if that is what it's called) is 2.25" diameter, so will do little to cool the flame. Therefore, I would be very concerned at the flame playing directly on the return end plate. The return path through the smaller boiler tubes will remove most of the heat and so reduce the flue gas temperature, so I am less concerned about the smoke box end.Why make-do with what's in the scrap box? Why not work to MIL TBD41 standards?For those who are not familiar with that standard, it stands for "Make It Like The Bl**dy Drawing For Once"
SNIPEDIT that flattening of a tube made me think you could make the baffle slightly curved and then that would help return the gasses
