Author Topic: Reconditioning a Stuart Dynamo  (Read 12388 times)
Offline Sanjay F
« on: January 30, 2024, 01:22:13 PM »
Having finished the Stuart compressor, I'm now onto a Stuart Dynamo. I did one of these before and had to change the armature which proved quite pricey!
I have a couple of questions before I start:
Has anyone managed to get 4v out of one of these; even after changing the armature (I didn't change the permanent magnet) and spinning up using a drill the best I managed was 1.5v? The current output is 0.143v, that's not even going to power a small torch bulb!)
This leads to my second question, what exactly is the black gunk which holds the permanent magnet in place, it feels like some sort of semi hardened rubber? It'll come off using a blade, but I need to replace it
How do I know which way round and which way up the permanent magnet goes; this is the innocuous piece of metal in the picture?
Does anyone know of a company that can rewind these armatures; all the companies I have found are for big stuff?
Thanks.................
Re: Reconditioning a Stuart Dynamo
« Reply #1 on: January 30, 2024, 02:15:39 PM »
Your drill may not be fast enough, you want at least 3000rpm so will have to use a larger drive pully to gear up the speed of the drill.
Offline Sanjay F
« Reply #2 on: January 30, 2024, 06:00:51 PM »
Ah yes, of course I didn't think about that!
I have learnt permanent magnets are not permanent; the one I removed from the old dynamo can barely pick up a nail compared to the new one.......let's see if that makes a difference.....I'm sure iit will, my schoolboy knowledge of electromagnetism says it will!
Online Roger B
« Reply #3 on: January 30, 2024, 07:03:40 PM »
It is also important that there is no gap between the magnet and the pole pieces.
Offline Sanjay F
« Reply #4 on: January 30, 2024, 09:32:16 PM »
Thank you and yes, I can see how that would be an issue
I need to get the polarity of the magnet right. Having watched some videos, I'm going to borrow the compass from my daughter's science kit; this should tell me the poles of the original magnet and therefore how they were placed into the casing. Using this method, I should be able to identify the poles of the new magnet and position in the correct orientation  :thinking:
I cannot explain how weak the old magnet is, but am hoping it will still deflect a compass needle ...... please......
I'm so glad I marked the magnet before removing it and didn't wash the writing off  :)
Looks like my daughter and I will be having some science fun after school tomorrow, best way to get them interested is to get them involved and away from staring into a screen!
« Last Edit: January 30, 2024, 09:42:57 PM by redhouseluv »
Offline Sanjay F
« Reply #5 on: January 31, 2024, 09:21:50 PM »
Simple solutions are the BEST!
Offline Sanjay F
« Reply #6 on: February 01, 2024, 06:46:39 PM »
After cleaning all the electrical contacts, armature, poles pieces and making sure the new permanent magnet was positioned correctly against them, I put the whole thing back together for a test run.......
Jackpot: it now generates 2.761v!!! That's a 1830.77% increase on where I started. I may soon be able to charge my phone using steam power  ;D
Online Roger B
« Reply #7 on: February 01, 2024, 06:58:35 PM »
Excellent  :ThumbsUp:  :ThumbsUp:  :wine1:
Some time ago in Brussels airport there were exercise bikes you could use to charge your phone  :)
« Reply #8 on: February 01, 2024, 07:02:07 PM »
I bet there were people waiting near those bikes with signs like '$10 and I'll peddle to charge your phone!'
« Reply #9 on: February 01, 2024, 07:16:16 PM »
Now there's a lofty goal!  :ROFL:
That's great! Wonderful that you got it to work  :ThumbsUp: :popcorn: :popcorn:
And I actually think that would be a really fun to charge you phone on steam! :)
Offline Sanjay F
« Reply #10 on: February 01, 2024, 10:40:23 PM »
I Googled it and guess what, someone has done it! (27:05)
No prizes for me........... I need to think of something else!
<a href="https://www.youtube.com/watch?v=Y2UEY04lKSU" target="_blank">http://www.youtube.com/watch?v=Y2UEY04lKSU</a>
« Reply #11 on: February 01, 2024, 10:49:13 PM »
I assumed that was what you were referring to!   :Lol:
I think it would be OK to do it yourself anyway.   The world can't have too many steam-driven phone chargers!   :lolb:
« Reply #12 on: February 02, 2024, 07:32:07 AM »
Well I've made a solenoid engine that runs off a phone charger so you could make an engine to run off the dynamo off a steam engine.
What speed is the drill running at, that may be the answer to getting more volts out of the dynamo. You could hook it up to the lathe if that is faster.
Offline Charles Lamont
« Reply #13 on: February 02, 2024, 02:18:22 PM »
I want to see a compressor running off a phone.
« Reply #14 on: February 02, 2024, 02:40:40 PM »
I tried running a compressor on my phone but the weight cracked the screen :LittleDevil:
