Author Topic: Hacksaw Frames.  (Read 14395 times)
Re: Hacksaw Frames.
« Reply #15 on: February 07, 2023, 01:43:51 PM »
Mine must be creeping very slowly as I can still tension a blade and it must be 40yrs old and never been slackened off for storage. :)
Re: Hacksaw Frames.
« Reply #16 on: February 07, 2023, 09:52:29 PM »
Mis read you Jo - as in blade only goin on in two directions and not two planes  :facepalm:
I have never seen one of those go bad over time - but like you, I don't enjoy 'holding them in the wrong direction' .... And like you I now have two never designs that are somewhat 'Wonky'  :wallbang:
Offline PJPickard
Re: Hacksaw Frames.
« Reply #17 on: February 07, 2023, 10:53:29 PM »
That Sandvik one that Dave showed is great! I got one at work from McMaster Carr and I liked it so much I had to get one for home as well.
Offline Mcgyver
  • Toronto
Re: Hacksaw Frames.
« Reply #18 on: February 18, 2023, 12:44:40 PM »
I bought a couple of the Lenox high tension frames awhile ago.  After using the ubiquitous tube frame with the wing nut for decades, they are so much nicer.  Highly recommended.
If unfamilair, the the silver grey bit atop the hand grip rotates.  Its gives a bit of leverage and lets you really tension the blade
Re: Hacksaw Frames.
« Reply #19 on: February 18, 2023, 09:29:00 PM »
They have changed over the years, here is a picture of my mine.
8 turns on the crank makes the blade fiddle string tight.
