Author Topic: small bandsaw repair/improvement..  (Read 7945 times)
Online tghs
« on: January 30, 2023, 03:57:45 PM »
my Little Machine shop 4829 small bandsaw that has seen little use started having the blade get out of the guides,, found that one guide mount/block did not have clearance and the bearing was binding,, in the removal part of this the threads and bearing bolts were buggered and stripped. :rant: picked up some new bolts,, drilled and thread inserted the base,, milled the blocks for a correct fit.. all is working well again..  :whoohoo: still not happy that this required doing..
what the @#&% over
Re: small bandsaw repair/improvement..
« Reply #1 on: January 30, 2023, 06:12:57 PM »
Too bad it happened :(  But excellent repair job!  :ThumbsUp:
« Reply #2 on: January 30, 2023, 06:45:17 PM »
Great that you got it running well again  :ThumbsUp: - but I agree - these things should last much much longer than some of them do  :wallbang:
