Hi Also wondering about the mains frequency in The USA is it 50 or 60 Hertz Cycles /second. ?? I thought that the US mains was 120 Volts still wondering .....!!!Willy
Thanks for all the advice! Can it be run from a VFD ? I don’t have 3 phase at home. Certainly wouldn’t want to change the motor out to one that can run from a VFD.ThanksMark
Quote from: gadabout on December 23, 2022, 10:32:27 pmThanks for all the advice! Can it be run from a VFD ? I don’t have 3 phase at home. Certainly wouldn’t want to change the motor out to one that can run from a VFD.ThanksMarkThere are lots of considerations if you are looking for maximum power and maximum efficiency. If you can deal with less than perfect then most motors will run on different frequencies, such as the range of frequencies produced by a VFD, or a simple conversion between 50 Hz and 60 Hz. It is important avoid overloading, of course.I would guess that this lathe does not have a huge motor. A possibility is simply replacing the motor with one that matches your existing power feed. Considering the value of this lathe a couple hundred for a new motor is almost in the noise. Probably less expensive than a new VFD.Gene
