Author Topic: Couple of model planes  (Read 1057 times)
Offline vtsteam
« on: December 16, 2022, 03:15:29 AM »
These are a couple of R/C model planes I built awhile back from scratch.
The first is a replica of my first ever R/C model built in 1964, a Sterling Mambo. The original was balsa and silk and powered by an O.S .19. At the time, since it would be my first flight ever, a fellow club member took it up for me, then handed me the transmitter (it was a single channel Citizenship with a Galloping Ghost switcher added-on). I totaled it after flying for less than a minute. I had taken me month to build it. I didn't build models again for 44 years.
The new Mambo fuselage was built from pink owens corning fanfold foam and covered with paper. The wing was solid wire-cut foam, also covered in paper. It flew nicely, and was a real soaring machine. It could thermal.
The "engine" in front was fake. It was just an aluminum casting sprue turned with fins to look the part. The actual power was a small electric outrunner, beneath. I hit on te idea for the faux engine because I'd built the plane so lightly that it needed nose ballast to balance. The chunk of aluminum at the very tip was just right.
The other plane was an original design for a Brown B-2 "Miss Los Angeles", carved out of solid foam. Also covered in paper. It was modeled after one of the Golden Age pylon racers. The Brown was a handful to fly, but exciting. Especially the first test flight, where I struggled to get it up high enough to be able to reach for the trim levers after an iffy hand launch with the model badly out of trim. I did manage to keep it away from terra firma and get it straightened out. But you definitely had to fly that plane, not like the Mambo, which if you throttled down would basically act like a big free-flighter, and you could set your transmitter down on the ground.
Offline Zephyrin
  • near Paris, France
Re: Couple of model planes
« Reply #1 on: December 16, 2022, 09:40:12 AM »
I know the red one, it is the "Stratonef H22", I still have these albums...
« Reply #2 on: December 16, 2022, 04:17:02 PM »
I especially like your "Miss Los Angeles" as I've long been interested in the air racing of the "between Wars" era. I have a scratch built Keith Rider R-4 hanging on a wall. This one is stick and tissue for rubber powered free flight, not RC, built from plans found on the web.
Offline vtsteam
« Reply #3 on: December 16, 2022, 09:43:41 PM »
I'm afraid the Stratonef H 22 exists only in the wonderful imagination of Tintin's author, and also Tintin himself, who has gone very seriously off course in his Paris to New York run, since he is in Antarctic regions, judging by the presence of ice floes and penguins!  :Lol:
Offline vtsteam
« Reply #4 on: December 16, 2022, 09:58:10 PM »
I love the KR Firecracker!
I designed and built couple of profile Caudron's for indoor free flight, one in foam and one in stick and tissue. The stick and tissue was the better flier, naturally.
@Zephyrin, the Caudron is your plane! Maybe Tintin's builder adapted one of those for cruising and painted it red!
