Author Topic: Eyesight not so good so I need a Cowells lathe!  (Read 5638 times)
Offline simplyloco
« on: October 17, 2022, 02:53:34 PM »
I'm still getting the monthly eyeball injections, there is some improvement. My EMCO V10P is great, but I need to get closer to the work, especially small bits that I'll find on my Stuart Triple, so I took the plunge and bought a second hand Cowells 90ME on you know where. The thread title sounds like a contradiction, but I can put it at eyelevel and use a head visor.
It's 15 years old, and looks well used,  but everything is adjustable, and it comes with lots of kit i.e.
Slitting saw, rear tool post, 2 front posts, 4 collets & Adaptor, 1 blank collet, die holder, fixed steady, angle plate, vertical slide and milling vice, face plate, 3 jaw chuck, 4 jaw chuck, test bar and catch plate plus other bits I don't recognise!
All at sensible money... :whoohoo:
« Last Edit: October 17, 2022, 03:29:33 PM by simplyloco »
Offline Grateful Ted
Re: Eyesight not so good so I need a Cowells lathe!
« Reply #1 on: October 17, 2022, 05:00:38 PM »
Eyeball injections can’t be much fun, but I’ve found as I get older I need to *modify* my lifestyle a wee bit.
I now need to stay off ladders, but I won’t bore you with that outcome.
That Cowells looks very capable & it’ll be great fun.
Cheers, GT
« Reply #2 on: October 17, 2022, 05:39:42 PM »
Nice buy  8)
If your eyesight is not so good I would recommend a DRO  ;)
 :headscratch: Why did she come with a spare headstock? Did someone over tighten it?  :noidea:
P.S. I hope you are going to replace that mains plug for one with insulated pins  :zap:
Offline simplyloco
« Reply #3 on: October 17, 2022, 05:43:12 PM »
Good advice. A whole new world is opening up!
Offline GWRdriver
  • Tennessee USA
« Reply #4 on: October 18, 2022, 12:40:23 AM »
Hello John,
Sensible money is a good thing!   :ThumbsUp:  I once owned an ME90, acquired for sensible money because I thought it would be good for my Gauge-1 and other small work.  It was, but so was my main lathe.
The problem I had with the Cowells was power.  I don't know if it was under-powered, because at any given setting belt slippage prevented 100% of the power getting to the spindle.  I wrote it down to the plastic belts and felt that rubber or Brammer-type belts would have cured the problem.  Other than that it was a very nice little machine.  I elected to sell it off, without replacing the belts, and I later found a CW90 which better suited my needs for small work.
Harry
Cheers,
Harry
Offline simplyloco
« Reply #5 on: October 25, 2022, 04:24:44 PM »
The lathe arrived today. The boxes were a bit heavier than I expected, and when I opened them the reason became clear. The seller had decided to clear his workshop and I was the lucky recipient!
Here's a better view. Hundreds of carbide tools, drills with ground 0MT shanks, 26 various 0MT hard/softcentres including a drill pad, cup and flange, 3 blank arbors, etc.etc.. Two live centres - male and female, precision chuck, unused fixed steady and other stuff too numerous to document!
It has the M1.5 spindle, and has obviousely done a lot of work, but I've overhauled the slides, trued up the tailstock (0.015" out), oiled up everything and it works fine e.g.
There is no perceptible runout on the SS 1/8"  bar...
I'm quite chuffed with it, although the RPM seems a little pedestrian for such a small lathe! I checked the speed using my Roman built mechanical tacho, and it was spot on 880, so I'm open to suggestions to speed things up a little. I also don't 'get' how the back gear works as the book says to disengage the driven pulley!
« Last Edit: October 25, 2022, 04:30:43 PM by simplyloco »
« Reply #6 on: October 25, 2022, 04:46:45 PM »
You should be chuffed!  That's a beautiful little lathe with a LOT of nice tooling to go with it!  I'd say you made quite a score there!  :ThumbsUp:
Congratulations!
« Reply #7 on: October 25, 2022, 05:26:10 PM »
Good haul  :o
Interesting they changed the baseplate casting over the years. You will need a magnifier to help you see your turning  ;)
Do you have its serial number?
« Reply #8 on: October 25, 2022, 05:28:45 PM »
Great collection!  Have you decided what its first project will be?
Offline simplyloco
« Reply #9 on: October 25, 2022, 06:17:51 PM »
It will help produce the smaller items on the Reeves Bolton Triple that I will be purchasing next week. One of these...
https://modelengineeringwebsite.com/Triple_expansion_engine.html?fbclid=IwAR2U8sLlgXscUhp3e7EreVtfpWLz48IdkBLwaTvXaamAnGAbshIuTWUxImU
The Stuart Triple castings are being returned.
Offline simplyloco
« Reply #10 on: October 25, 2022, 06:20:34 PM »
Good haul  :o
I haven't (daren't!) look!
I only paid £985 for all this so I don't really care how old it is! :old:
Online Twizseven
« Reply #11 on: October 26, 2022, 12:00:20 PM »
That looks a fantastic buy with all those extra bits.
Jo mentioned you should fit a DRO.  I fitted one to my Cowells lathe (and Cowells Mill).  Used magnetic scales and the Touch-DRO software.  There is a post on this site about it but the photos vanished.  The photos can be seen in my album over on the Model Engineer website.
Have fun.
Colin
Offline simplyloco
« Reply #12 on: October 26, 2022, 12:13:03 PM »
Have fun.
Colin
Thanks Colin, I'll take a look. Before I installed the DRO on the EMCO I used slip guages on the bed stops, which may do for now. Right now I'm more interested in increasing the spindle speed. I spoke with your namesake at Cowells this morning who said I could fit the twin pulley but I'd have to carve lumps out of the motor housing!
We shall see...
« Last Edit: October 26, 2022, 12:19:03 PM by simplyloco »
Offline simplyloco
« Reply #13 on: October 28, 2022, 06:44:55 PM »
A short video for you! I made a larger drive pulley so I was still able to use the existing drive belt.
<a href="https://www.youtube.com/watch?v=aeuyPbMQXUk" target="_blank">http://www.youtube.com/watch?v=aeuyPbMQXUk</a>
« Last Edit: October 28, 2022, 07:01:39 PM by simplyloco »
« Reply #14 on: October 28, 2022, 06:58:50 PM »
Looks like the video is marked private, so it won't play. Needs to be set to shared or public on the host, youtube?
