Author Topic: Stuart No. 1  (Read 11533 times)
Re: Stuart No. 1
« Reply #15 on: April 20, 2024, 06:16:00 PM »
Hello Willie,
Here are a few pictures of the valve. Maybe that's enough for you to create your own design for such a valve. If I could master CAD drawing it would be easier to draw you a blueprint. But unfortunately I'm too stupid for that.
Re: Stuart No. 1
« Reply #16 on: April 20, 2024, 06:25:43 PM »
I think if you can incorporate a small Kohnian groove into the bore in the rotary piston, then an even better controller characteristic would be possible. The valve then does not open as quickly. I always use graphite grease on the sealing material for steam. And I have had good experiences with Anti Size in the valve.
Greetings Michael
Offline SteamBoatWillie
  • Jr. member
Re: Stuart No. 1
« Reply #17 on: April 21, 2024, 04:08:18 AM »
That's great, Thanks!
