Author Topic: CAM SPEC QUESTION(S)  (Read 1539 times)
Offline sid pileski
« on: January 28, 2022, 04:49:06 PM »
Good day everyone.
I'm in the very early stages of designing an engine that will be loosely based on one that a friend of mine has a full size version of.
It's a single cylinder 4 stroke boat engine, probably from the 20's-early 30's.
I like it because it used a set of 90* helical open gears to run the cam, to a set of rockers, to push rods, to another set of rockers, to the valves.
The bore right now is 1.5". Stroke not yet determined.
I want this to run slow.
It will, per the prototype have a large solid flywheel. I'm thinking no more than 5:1 compression.
Now the cam spec question.
What will be the best specs for a good slow runner?
From some reading, no over lap.
But, what else makes for good idle performance?
Also, small carb
Thanks, Sid
Online Vixen
Re: CAM SPEC QUESTION(S)
« Reply #1 on: January 28, 2022, 04:58:51 PM »
Hello Sid
There are some discussions about various  valve/ cam timing events over on the 'Bristol Hercules sleeve valve radial engine plans' topic. Around Reply #62 various valve/ cam timing events are discussed (not just sleeve valves). You may something useful there.
Offline AVTUR
  • West of England
« Reply #2 on: January 28, 2022, 05:16:24 PM »
Sid
I think you have included the main features for good idle performance; large flywheel, mild valve timings with low lift and low compression ratio. A stroke greater than the bore could help.
All these would reduce the engine's acceleration but I doubt if that is of concern. There is something rather nice about soft engines.
AVTUR
Offline sid pileski
« Reply #3 on: January 28, 2022, 05:24:12 PM »
Hello Sid
I'll check it out.
Any other insights?
Thanks, Sid
« Reply #4 on: January 28, 2022, 06:40:21 PM »
Before you spend too much time on this: Have you priced up the Helical gears  :paranoia: Or do you intend on cutting your own  :)
« Reply #5 on: January 28, 2022, 06:49:18 PM »
You could take a look at some of the other designs from the period but would need to weed out the ones that were more designed with performance n mind.
If you can also arrange an easy way to advance and retard the ignition timing that will allow you to slow things down a lot.
This 1934 design that I scaled down also had the valve lift reduced quite a bit as I wanted it to run slow and sound good as it will never get used in a tether boat
<a href="https://www.youtube.com/watch?v=v1WTcKEt--s" target="_blank">http://www.youtube.com/watch?v=v1WTcKEt--s</a>
helical gears need not be that expensive if you can use standard helix angles, I've used these for an engine which I thought were very reasonably priced
https://ghw-modellbau.de/index.php?cPath=91_83_88_211_213
Offline sid pileski
« Reply #6 on: January 28, 2022, 08:29:01 PM »
Helical cam gears are already on order and in the mail hopefully from HPC gears.
They had just what I was looking for, and in stock at a very reasonable price.
Sid
Offline sid pileski
« Reply #7 on: January 28, 2022, 08:30:25 PM »
Yes, ignition timing goes without saying.
Guess I should have mentioned that too.
But thanks for pointing it out.
Sid
« Reply #8 on: January 28, 2022, 08:49:31 PM »
Keep us posted on progress, I've fancied doing an old boat engine like a Calvert or similar for a while. I've also got an inkling for an early outboard.
Offline Longboy
« Reply #9 on: February 01, 2022, 10:09:46 PM »
Good day everyone.
Also, small carb.
Thanks, Sid
Slow stead idles kinda blends in a perception of easy running and a steadfast reliability in model engines. Your exhaust valves should close right near TDC. The compression should be lower than 5:1.  Ignition timing right around TDC. A .10/.15 model engine carburetor the right size. The greatest influence on engine speed will be the flywheel diameter. You can knock down over a hundred RPM increasing your diameter by one inch.
I like bevel gears too! Look over on EBAY for the China specials.   Luck to you, .....Dave.
« Last Edit: February 01, 2022, 10:21:08 PM by Longboy »
