Author Topic: Mike's Completed Upshur Horizontal Farm Engine  (Read 597 times)
Offline mikehinz
« on: December 29, 2021, 01:10:47 AM »
All, the following are the final pix for my Upshur Farm Engine build.
For reference, the build log is here:
https://www.modelenginemaker.com/index.php/topic,10531.0.html
The only work I did after the build log was to mount the engine on a wooden base and attach a name plate to the base.  The wood is walnut and is from trees that grew on the farm where I grew up.  My late father felled them and had them sawed in rough lumber.  My brother carefully store the rough lumber and made this base from a small piece.  He's a very skilled woodworker so I get him to do whatever woodwork that I need and I trade him out with any machining that he needs.
The brass plaque was made at a local trophy/engraving shop that does good, fast, work.
I didn't attempt to finish this engine to a fine showroom type condition.  The machining is good, at least in my opinion, as my goal was to build an I/C engine with several features that I hadn't attempted before.  What was new to me on this build was the entire hit-n-miss mechanism and building a carburetor from scratch.  The carb was from plans originally done by Chuck Fellows and then replicated by Brian Rupnow and others.
I also don't attach a permanent fuel tank to the engine as this will go into the house and I don't want even a trace of fuel inside my house.  I also only leave the spark plug and hall effect sensor attached to the engine as I move the S/S module from engine to engine as needed.
In any case, here are the final pix:
The name plate:
The rest of the pix are of different views of the engine.
And finally two short videos of the engine running:
Left side of the engine showing the governor working:
<a href="https://www.youtube.com/watch?v=XUwN_to9GkM" target="_blank">http://www.youtube.com/watch?v=XUwN_to9GkM</a>
Right side of the engine:
<a href="https://www.youtube.com/watch?v=0J0nUNpUci0" target="_blank">http://www.youtube.com/watch?v=0J0nUNpUci0</a>
And that's it!!
I enjoyed building this one and am already starting the build on another project engine.
Enjoy!
« Last Edit: December 30, 2021, 12:46:26 PM by mikehinz »
MIke
Wichita, KS, USA
Re: Mike's Completed Upshur Horizontal Farm Engine
« Reply #1 on: December 30, 2021, 03:22:04 AM »
That is one fine looking and running engine, Mike. I love that the base has a real heritage too! Looking forward to your next build.  :cheers:
« Reply #2 on: December 30, 2021, 10:40:05 AM »
I can only agree - lovely story and presentation  :cheers:
« Reply #3 on: December 30, 2021, 12:08:07 PM »
Very nicely done!  Something to be proud of!
Offline mikehinz
« Reply #4 on: December 30, 2021, 12:49:35 PM »
All, thanks for taking a look!
The finish on the engine isn't nearly as fine as some of the one's I see here, but it runs and the flywheels run true!  The wooden base though is very nice, so thanks for noticing that.
I did modify the post as I had duplicated the links to the videos. Now you can see the both sides of the engine when it's running.
Again, thanks for taking a look!
MIke
Wichita, KS, USA
Offline scc
  • Lancashire, UK
« Reply #5 on: December 30, 2021, 08:13:29 PM »
Very nice Mike :ThumbsUp:        Terry
Offline pmerritt
  • Bloomington, Indiana
« Reply #6 on: January 01, 2022, 06:39:08 AM »
Very nice engine Mike! I just fired up the one I built yesterday for the first time in months. I really like the Upshur engines.
