Author Topic: A small dividing head  (Read 2145 times)
« on: June 08, 2021, 01:46:54 AM »
Before starting the next engine project I decided to build a diving head that can be used on either my Taig mill or lathe. With a tip of the hat to a dividing head published by Tony Jeffree, I came up with my own design built around a Taig headstock spindle and a 30:1 worm gear. The frame is based on two pieces of 3” x 3” aluminum angle, which will be trimmed and screwed together to give the “box” dimensions I want. A riser block will raise it high enough for the 4 jaw chuck to clear the mill table, but with the block removed it will be on be on spindle center line when bolted to the lathe cross slide
The hub of the gear wheel I have is 0.75" diameter, which doesn't leave much meat for a set-screw after boring to 0.67" for the spindle. So I made an “auxiliary hub” from some 0.875” hex brass. I turned a short .25” spigot on one end to center it in the gear bore for silver soldering, and a longer 0.375”  on the other side so it can be mounted in an ER-16 collet for boring and parting off.
« Last Edit: June 08, 2021, 02:10:22 AM by RReid »
Offline kuhncw
Re: A small dividing head
« Reply #1 on: June 08, 2021, 02:32:08 AM »
Ronald,
That is an interesting design.  I'm looking forward to your build updates.
Chuck
Offline joe d
  • Montreal, Canada
« Reply #2 on: June 08, 2021, 02:35:50 AM »
Ron:
I built one more or less to Jeffree's design, it's been very useful.  I suspect you will like yours once you've completed it.
Joe
Offline Thor
« Reply #3 on: June 08, 2021, 05:00:48 AM »
Hi Ronald,
 Your dividing head looks very nice. I too was inspired by Tony Jeffree to make my own dividing head using a MT 2 spindle from a Sieg X1 milling machine: http://files.thor-hansen.webnode.no/200000013-0eebe10dd7/Delehode2.pdf
Thor
« Reply #4 on: June 08, 2021, 03:44:14 PM »
Chuck, Joe, and Thor - Thanks for the input guys, much appreciated!
A note on the drawing might be in order. At the bottom of the page in the first picture you can see printed "Solidworks Eductional Product". I don't know if this is commonly known within this forum or not, but one of the nicest perks of a membership in the Experimental Aircraft Association (EAA) is a free annual license to that version of Solidworks. At only $40/year it's a bargain for 3D modeling software that is hardly reduced in functionality at all versus the big buck full version.
« Reply #5 on: June 09, 2021, 12:42:58 AM »
Most of today's work involved easy but slightly boring brass boring. That included the gear wheel and two bushings to support the spindle in the frame. Didn't take any process pictures because, as usual, I forgot to. Pretty standard stuff anyway. Here's the end result.
That portion of the spindle to the right of the nut will be surplus, and I'll cut most of it off eventually. The only part still to make for the spindle is the brake.
« Reply #6 on: June 11, 2021, 01:11:44 AM »
Switching focus now from the spindle to the frame. The frame consists of two pieces of nominal 1/4” x 3” aluminum angle. The “A” piece forms the base and the front (working) face. The upright leg was cut down to 2.5”, and both faces have to be machined for flat and square. Here I'm about to flycut that front face. These are very light cuts, so the blocking isn't really needed, but helps to dampen any vibration. Also visible is the 3/16” pilot hole that locates the future position of the spindle.
And the result.
Next was to drill and tap 6 6-32 holes to fasten the “A” and “B” angles together. A selection of table clamps and C clamps keep everything together and in line. Three of the screws go up from the bottom, so those holes were also counterbored with an end mill to accept the heads of the SHCSs.
I usually start taps either in the drill press or the mill. In this case I did the drilling on the mill, so the tap goes into the chuck which is held by loosely tightened collet. The collet holds the chuck vertical and aligned, but is loose enough for it to slide up and down, making it easy to start a few threads worth by hand. Then over to the bench to finish the tapping, knowing the tap has been started straight.
With the basic frame now assembled, it's time to think about boring it for the spindle. I plan to do this on the lathe, first with drills then a between centers boring bar. Here I've mounted the frame to the cross slide and am indicating it in.
Then I lined up on that previously drilled pilot hole, and drilled through the back face.
Ultimately that bore needs to be 0.8” diameter. I'll go as far as I can with drills, up to 0.75” if all goes well. Then switch to a boring bar, which I will have to make. Hopefully out of this old piece of shafting.
« Last Edit: June 16, 2021, 01:37:52 AM by RReid »
Offline Thor
« Reply #7 on: June 11, 2021, 07:44:17 AM »
Hi Ronald,
 You are making good progress. Using a between centres boring bar will make the holes for the spindle the same diameter and parallel to the lathe bed.
Thor
« Reply #8 on: June 12, 2021, 12:52:34 AM »
I left off yesterday having drilled the start of the spindle bore to 3/16”. Today I continued drilling, going up in steps each time. Here is the last drill I used, 5/16”. It's roughly half as long as the lathe bed!
I could have gone a little farther with drills, but I decided that since I now had clearance for that piece of old shaft I showed previously, I would switch from drilling to boring. But first I had to drill the bar for a cutter and a set-screw.  Turns out that key slot was really handy. It provided a nice indexing surface, making it easy to rotate the work 90 degrees for laying out and drilling those two holes. Here I'm laying out the center line of the first hole by measuring from the fixed jaw of the vise.
Then rotate and do the set-screw hole. I start taps on the drill press by turning the spindle by hand while applying downward pressure with the quill handles. Just a few turns, then back out carefully. A little dab'll do ya, then finish on the bench.
Here's the boring bar, mounted between centers (well, between 4J and center), cutter installed, ready for work. The cutter was ground from a broken center drill. Because of its geometry, the cutting edge is facing “down” and towards the headstock, so the boring proceeded by moving the carriage from left to right.
Almost there.
Success! Everything fits and the spindle turns nice and smooth. I'm pretty pleased with how that went. There's obviously no micrometer adjustment on that boring bar, so it would have been easier to have turned the bushings to fit the bore rather than the other way around, but it worked out by going slow and careful.
« Reply #9 on: June 17, 2021, 12:31:41 AM »
Well, it's not quite a dividing head yet, I still need to make a division plate and the attendant stop pin, etc. But with a simple utilitarian crank, it can now be used as a rotary table. At least I think so, I haven't had a chance yet to actually prove that. :thinking: At least the chuck goes round 'n' round when I turn the crank.
Since the Taig spindle I used has a “bearing pre-load nut” at the far end, which I retained but don't have any bearings to pre-load, I think I can use that nut as an effective brake, eliminating the need for a separate one. You can see it in this last picture.
« Last Edit: June 17, 2021, 12:45:29 AM by RReid »
« Reply #10 on: June 17, 2021, 12:38:48 AM »
Can you use it in rotary table mode to make the division plate?
Do you need different plates for different numbers of gear teeth when cutting gears? I've never used a dividing head, don't know the ins and outs of them.
« Reply #11 on: June 17, 2021, 01:07:35 AM »
Yes....standard B&S dividing heads have 3 plates....they can be reproduced with what is there!....it's a lot of work, but it is doable.
RW Smith did a great write up on making indexing plates using a tape measure tape wrapped around a disk as a master...and made clock wheels with the result!....also remember, what ever error you have in the position of the holes in your plates, will be reduced by the gear ratio of the dividing head....so that helps alot.
« Reply #12 on: June 17, 2021, 01:19:38 AM »
Yes. For example, since I used a 30:1 worm gear set, every full turn of the crank moves the work 1/30 of a revolution, and by drilling a hole at each turn of the crank, 30 full turns would produce a 30 hole division plate. Such a plate could then be used to make a gear (or any other segmented part) with 30 teeth or any other number of teeth that is a factor of 30 (2, 5, 6, etc.).
The other way division plates are sometime generated is by using a circular saw blade as a temporary indexing wheel.
It really depends on how many different gears you want to make. One plate typically has more than one hole circle in it, but multiple plates with multiple rows are usual for a comprehensive set. For my needs one plate with maybe three rows of circles (30, 36, & 50?) will probably be more than enough.
I've never used a dividing head either, I'm in learning mode too!
« Reply #13 on: June 17, 2021, 01:38:14 AM »
Ron....what is the gear ratio?     40 to 1 or something else?
« Reply #14 on: June 17, 2021, 01:56:50 AM »
The gear ratio is 30:1.
« Last Edit: June 17, 2021, 02:00:07 AM by RReid »
