Author Topic: Did I realy do that?  (Read 28207 times)
Re: Did I realy do that?
« Reply #30 on: September 06, 2021, 06:34:36 pm »
That was a  :censored:
If such horrors happen I use a piece of Sellotape over the top and when it is almost dry use a razor blade to trim it level with the bed  ;)
« Reply #31 on: September 06, 2021, 06:48:19 pm »
Thanks Jo,
Sellotape and a heavy weight attached as per your instructions.  :embarassed:
I will have to use a brand new Stanley knife (box cutter) blade as my three blade Gillette razor blades wont 'cut it', as they say.
  • Oregon
« Reply #32 on: September 07, 2021, 01:52:40 am »
The downside to teaching yourself G-codes on a brand new, $30K CNC Bridgeport is the 1/4 inch hole neatly, if noisily, drilled into the the shiny new table. And having to re-tram the head after calming down (at least it was bought with someone else's money).
« Reply #33 on: September 07, 2021, 03:53:20 am »
As the title says: Did I realy do that?      :lolb: :lolb:
Then, did I realy try to drill a hole with it?
Concentrate lad          :hammerbash: :hammerbash:
Heck, I’d just write this off as not being able to see that well anymore.
