Author Topic: Crowning a pulley for a flat belt Question  (Read 367 times)
Offline Jim
« on: March 03, 2021, 11:02:23 PM »
Crowning a pulley for a flat belt, been trying on some ali before moving onto brass using the top slide set at 1 + and then set at 1 - and it ain't an easy exercise to achieve a simple crowned pulley!
Any hints on how to do this? I thought this was going to be really simple, its kicking my arse!
Kind regards,
Re: Crowning a pulley for a flat belt Question
« Reply #1 on: March 04, 2021, 12:50:40 PM »
1 degree isn't much....5 might be better for belt tracking....try it out on the ali part first
A dead sharp tool with a small polished radius and a steady feed...consider a simple crank on the compound that you can spin smoothly
Got some pictures?    Lets see what it's doing?
Offline Mcgyver
  • Toronto
« Reply #2 on: March 06, 2021, 12:02:24 PM »
I've only seen them with a curve not two flats so thats how I've made them.  You could create the radius the way I do radii; work out a table of X/Z movements and cut the steps with the compound and cross feed.  I think on the one below I just eyeballed a few steps and hit it with a file, its not super critical stuff.  Then finish with a file and emery to round out the corners of the steps.
