Nice work on the lever - is that from solid or two pieces soldered together?
Looks great! What is the chalk trick? I am not familiar
Quote from: Rledoux313 on September 02, 2026, 04:35:26 pmLooks great! What is the chalk trick? I am not familiarRubbing the chalk onto the file before filing prevents the file surface from clogging up with fine metal particles: here's a 20 sec YouTube short:https://youtube.com/shorts/CRwiSALW90I?si=hQcyKqYo3iyB3L0m
Hi Sanjay, just use the edge/corner of a piece of brass sheet pushed along file teeth to push out the bits of metal that get jammed in the file teeth which won't come out with brushing. Andy.
