The way that I learned to scribe centerlines on boat spars will work here as well. For them, a block of woood several times longer than the width of the piece to be scribed, length does not matter. Add blocks at either end taller than the piece to be scribed. Then measure from the insides of each block to the other, mark the center, and drill a hole for a pencil or scriber. To use, position this 'tool' onto the piece, rotate it till the two blocks touch the side, and lower it till the pencil/scribe touches the surface. It will self center the scriber - then just push it along the length, marking the piece. Very simple to make, works great.Here is a link to something of the sort, made from a single block and having two scribers to lay out for making an octagon (this is not my site, found it by searching for 'spar gauge' ). Same thing works with one scriber in the center for your use.https://hub.shapertools.com/creators/5e4d9fa3c8f2b1000fb45be5/shares/63bc94f950c65c5f829cddbe
The usual way to use a surface gauge is to set it to approx height and lightly scribe a short 2-3mm long line. Then flip the part over and do a second line opposite the first. You then adjust the scribe until it is mid way between those two short lines and try again, keep doing it until the scribed line is central then you can run it along the whole part. This method allows you to scribe right to the end unlike the method above.
If you put the hex in your three jaw chuck in the lathe and put a square against the front two jaws of the chuck you will find your lathe tool tip is at the centre height (or so fractionally below as it does not matter). A lathe tool can now mark the centre line.
Ah ha - I got it too now I read Jo's words a few times over but its clear now and a really neat way of finding the centre line
