Model Engine Maker
Supporting => Tooling & Machines => Topic started by: Graham Meek on June 19, 2014, 08:08:18 PM
Further to a request from the Moderators I have been asked to share my modifications on the drill grinding jig.
These jigs can be obtained from various vendors and come in a wide range of colours. The newer jigs are a copy of an Original grinding jig marketed by Picador. I do not know for sure if this was manufactured under license in the UK from a firm in the USA or the other way around. The fundamental difference with these jigs to those that are currently on the market is that they grind the drill differently due to their construction. The Picador has a vertical pivot point which means the facet is ground with a cylindrical profile. On the more current versions this pivot post leans towards the grinding wheel, because of this lean the drill facet is now ground with a conical form.
Depending on the approximate decade of manufacture this lean varies between 6 and 12 Deg. Those with a 6 Deg lean usually do not grind a drill with the correct included angle. I think the reason for this is the guy who moved the moulded scale to compensate for the change to the original vertical post moved the scale the wrong way. If you look at my photograph of the jig with an engineers square against the drill facet you will see there is an additional 7.5 Deg wedge inserted in the base to rectify this error.
These jigs are and have to be accepted as a compromise. They are trying to grind drills from nearly a flat bottom through to a 90 Deg countersink. The worst case is the last as it will soon be realised this drill point is going to require a lot of relief on the heel of the drill to allow the drill to cut without it rubbing on the heel. The relief is inbuilt and constant and is based on the 90 Deg included angle, this is accomplished by an offset between the drill location vee and pivot point centre line, it is approximately 5 mm or 0.2". This is hard to tie down as this dimension also varies. It is this eccentricity that is the key to the modification and a broader understanding of the what is required when twist drill grinding.
What has never helped these jigs is the Instructions supplied with the jig, some instructions say the drill must project by one diameter, (D), while others say 1/2 D. Some say the cutting edges should be vertical while others say they should be over at an angle. I have also been told that the instructions do not even translate from the other languages to give the same sort of instructions. This is sorry state of affairs and small wonder why these jigs usually end up under the bench.
Having used a Picador jig from time to time I had always had a good drill, even though the process was a bit fiddly. I usually reserved it's usage for grinding my neighbours or relations drills which always seem to come by the sackful. Preferring to grind my own free hand. I was therefore a little curious when a poster said "these jigs are useless" knowing that I have had good results. The above is some of the things I have found out in the interim and goes to show that not all of them are useless.
The only object of the exercise was to make these jigs more user friendly, have a tool that was a valuable asset and that produced factory standard ground drills without the fiddle factor that was usually required to get a good result. As most of these jigs end up sold on, under the bench or in the scrap bin the outlay involved to procure a donor jig is minimal so the reader could have at the end of the day a very valuable asset if they follow my lead. The down side is once word gets out that these jigs are a valuable resource the price will go up.
I hope you have found this post informative, I will endeavour to give you follow-up reports, in the meantime the modified jig will grind drills from 1.5 mm (1/16") to 25 mm (1") diameter without fuss although the sub 3 mm (1/8") need an additional element made to cater for this size range.
My best regards
Gray,
Sorry forgot to load this photograph,
Gray,
:thinking: You have now got me thinking I might have to go and check the angle on my one, it never seemed right. I also have the top end of a rather better quality drill grinding jig but not the bottom half I wonder if it could be made to mount on the Union T&CG :noidea:.
P.S. That does not mean I am turning down trying out that Dormer drill cutter grinder :naughty:
Well I have found my Picador drill sharpening jig :-\ but the fit of the top into the bottom has about 5 degrees of wobble :facepalm: And it looked square for this drill at 68 degrees :headscratch:
Then there are these other two which are made of slightly better quality metal, but both are missing their bases and I suspect neither heads are complete :shrug:
Hi Jo,
The jig you have looks about the same vintage as my donor jig, and to me it looks like the pivot pin in the base is leaning. When you say there is a wobble are you referring to the free play in the joint where the angle detent is not firmly into the vee location on the mating part, if so there is a quick fix for this problem.
The Crackle black finished attachment that you have looks like the attachment for an early Deckel cutter grinder, but I am not sure. The last jig looks like another such attachment but for some long lost machine.
My best regards
Gray,
The one on the right of Jo's photo is the upper part of a "Reliance" drill grinding jig
Phil
Gray it is the pin that is too small for the hole it mounts in :headscratch: It would be nice to get that one working properly :ThumbsUp:.
Thanks Phil, I found a couple of photos of the reliance sharpener. I think that the quality of that reliance head is more in keeping with the union but the problem is time: Nothing is going to get done this side of the rally :wallbang: But I hear someone has time and is off to a :DrinkPint: garden party this weekend 8)
Jo,
I had one of those Picador drill grinding jigs, it came from Sarjents in Reading, which did reasonable service for nearly 20 years. It got left behind at some point in time. On mine and I think just visible in your first picture the main support was held in place by a piece of spring (originally) steel holding the stem upright and in good contact with the base casting when new. Eventually the spring went soft and the jig leaned over.
The base was intended to be fixed to the bench alongside the grinding wheel and the slot allowed the user to adjust the distance from the wheel to the jig.
Seeing Graham's work makes me wish I still had mine. :'(
Jerry
Thanks for putting this her Gray, it's much appreciated.
Cheers, Hugh.
I have one of the picador jigs, inherited from my late grandfather.
Having recently set it up I had the same issue as Jo with a wobbly stem - I found removing the screwed on plate that retained the stem in the base v-shape and packing behind it with some brass shims tightened it up perfectly.
Then I spent a happy few hours resurrecting all my old and broken drills. Beware,as word gets round you will find yourself doing the same for family and friends!!
The problem with these jigs is that on their own they all look the same. It is not until you get a Picador next to a modern clone that the differences become obvious. As stated before the Picador unit can produce good results with a little fiddling, the modified clone will produce a ground drill as good as you can purchase from a reputable manufacturer. The Devil is in the detail, and it is the fact that these jigs are being asked to grind a multitude of angles that is there downfall.
My modification does not retract from the original jigs capabilities, they are still there but what it does do is make the results far easier to achieve by providing a means of adjusting the relief angle to suit the drill diameter. It is no longer one relief angle fits all.
My best regards
Gray,
ok so mine is a clone not a Picador :(
So Gray where do I start trying to sort it out?
Hi Jo, & Edward
The modification to the base vee is shown in the opening post in the "close-up of the eccentricity scale", a piece of 20x20x3 mm BMS angle has been fixed into the existing vee and the original retaining plate replaced. The post nearest the camera stops the plate from moving when rotating the new eccentric. Hidden from view a spring is fitted between the plate and the base casting to provide a means of adjustment.
These mods can be done to a Picador unit with advantage, BUT the Picador unit grinds the drill Facet on a totally different principle, purely because the pivot stem is vertical.
Hi Gray,
A good write up. There's a couple more of these at the scrapyard (or there were on Wednesday) ! I was tempted to grab them both.
Maybe next time...
Hi Gray,
thanks for continuing the drill grinding jig "saga". Baron, thanks for the pictures showing the difference between clones and Picador. Could you tell us the angles of each with respect to the table?
Thor
Hi Baron,
Get them they will appreciate in value shortly.
Hi Thor,
The Picador pivot is vertical, the clones can lean any where from 6 Deg to 13 Deg, a lot depends on what era they are from, the newer jigs tend to be 13 where they should be to conform to L. A. Van Royen's Twist drill grinding jig, which is what I based my modifications on.
My best regards
Gray,
Sorry I have been absent for a while, I have been busy writing. I have attached a couple of up-close photographs showing nearly the full range of drills ground to date, the only one missing is the 1" Blacksmiths drill shown originally in the opening set of photographs. The smaller drills below 3mm or 1/8" diameter require a special holder and an alignment jig, purely because I have not the necessary number of hands required to carry out all the adjustments and hold the magnifying glass to see the drill lips.
My best regards
Gray,
Hi Gray,
Bugger ! Some one has beaten me to those drill jigs... Ah well you can't win them all :)
Hi Baron,
The word must be out, old drill grinding jigs shortly will be like "Hen's Teeth".
My best regards
Gray,
Thoughts of my old tools prompted me to search for a Picador. Guess who's been lucky. ;D
It just needs a clean-up perhaps following Graham's improvements.
Jerry
Hi Jerry,
The value of these units is going through the roof. I saw a genuine used Picador one on a trade stand at Bristol in August and the price tag was £38, I paid less than £5 for my used Far Eastern not so good copy of a Picador from a car boot sale.
Since writing this post I have written an overview of the modifications and this has been published here,
http://www.modelengineeringwebsite.com/Drill_grinding_jig_1.html
The more in-depth technical article with drawings has been sent to Engineering in Miniature, when this will be published I cannot say as I understand Editorial changes are taking place at Tee Publishing at the moment.
My best regards
Gray,
Hi Graham,
Thank you for your link. Having read the information and looked at the pictures I suspect my Picador may be one of the very original versions, it looks surprisingly like the one I bought in Sarjents over 30 years ago. (Happy Days :DrinkPint:)
This has slotted screws rather than PK, Phillips or Posidrive. Additionally the nameplate has the raised lettering infilled with blue.
For such an early unit it is in surprisingly good condition with hardly any marks on any of the mating parts, except on the square bar where the and screw as caused an indentation by being over tightened. Even the box is in good nick, although the staples have rusted and stained the cardboard.
I'm looking forward to trying to get the unmodified version working in the fashion set out on the instructions on the yellow label stuck to the box lid before I do any modifications, following your method.
Jerry
Hi Jerry,
I was given a Picador many years ago, I have used it mainly to regrind, the neighbours and my relations drills which seem to come by the sack full. I have always had good results with that unit, it is streets ahead of the reproductions. The only downside is the amount of offset built into the jig because the jig is being asked to grind so many angles, but I am sure you will be happy with the results.
My best regards
Gray,
We have that identical drill grinding gadget over her in the US, only it has a Sears Craftsmen 9-6677 label on it. If anyone wants mine, it's free if you pay the shipping cost. I bought a Darex drill grinder and find I have no use for this problematic tool. I don't like it at all.
Mosey :ThumbsDown:
Remembering this thread and we just found a General Model 825 in a cabinet at school that looks
exactly like one of the above pictures of a Picador. The rotation axis is tilted at about 8 deg as close
as I can tell measured with a long 3/8 rod in the base and protractor head on a "square". It looks like it
would do a decent job with bits from 1/2 down to maybe 3/16 or so.
SO! I have a "Plan" :-) How about building a scaled up version to handle both Silver & Deming bits
up to 1-1/2 " and taper shank ones up to the largest we have 1-3/32 by 12" long. :-) The big/only
problem will be the grinder to use. No way to hang this sort of thing on either of the Baldor bench
grinders we have.. I'm "thinking" about some sort of steel base that could be held on the mag chuck
and using the surface grinder. Any comments on this part of the plan????
The "fit and finish" of the as cast assembly of the General leaves me a bit or more than a bit un-happy.
Pinching a 3/8 steel shaft between a thin spring steel flat and the as cast Aluminum V of the base just
begs for something more sophisticated. :-)
There are, in the wood shop 3, 12" disc sanders. Any one with experience using one of these with
?some sort of PSA disc of what material and grit to grind normal drill bits?????
To handle the 12" long taper shank bits the fixture is going to pretty big and heavy so a major support
structure is envisioned.
If it comes about pictures and sketches will be forthcoming. :-)
...lew...
Hi Lew,
In the modifications I made to the existing drill jig by adding Bright Mild Steel angle to the drill rest, the additional rest and a longer adjustment bar, the as modified the jig will comfortably take 1.500" diameter taper shank drills.
Yes the 3/8" pivot is a bit of a problem area that is why I added another piece of BMS angle here to take a larger eccentric pivot bearing that allows the large offset of the original design to be varied to suit each drill size.
I would not be without my modified unit now, and all it cost me was some time which I hopefully have plenty of and the price of a decent cup of coffee, (the materials came from the scrap-box).
My best regards
Gray,
Some interesting stuff here as well:
http://www.gadgetbuilder.com/DrillSharp.html
Given the popularity of ER32 collets I'd really like to see someone build a jig using them.
Yes John wrote an article in HSM some months back now on the construction of this useful tool. Because I have limited space in my workshop, if I am pushed for a 4 or 6 facet drill I usually use my 2/3rd's full size Quorn to accomplish the task. I also use the Quorn to regrind the split point drills that I have in conjunction with the drill sharpening jig.
My best regards
Gray,
For those who may want the words and drawings on how to modify one of the jigs, or should anyone come to this post in the future, the article starts in the March 2016 issue of Engineering in Miniature.
My best regards
Gray,
Not wanting to hijack this thread, it inspired me a lot.
But, if anyone can explain the thoughts behind the geometry of this commercial variant of a drill sharpeing fixture... To me the geometry is totaly the other way round... We have one of theese at work, will try to sharpen my lager morse taper drills in this, wonder what the outcome will be..
The son of a late friend has asked my help in sorting out, and selling off, unwanted items from his fathers workshop. I was interested to come across this thread as amongst the items to be sold are two drill sharpening jigs, one by Spiralux (the silver one in the photos), which looks identical to the one at the beginning of this thread, and the other is by Reliance.
Hi Ray,
Thanks for posting the photographs, the first picture has solved a mystery as to why I had to put a 7.5 degree wedge under my Far-Eastern clone. The clone copy missed out this vital Spiralux addition to the base. The Spiralux would however benefit from fitting the adjustable eccentric to control the drill off-set. The Reliance jig on the other hand is a much better design.
My best regards
Gray,
Following on from the publication of the article I have received a query concerning the amount to be removed from the drill location vee in order to get the end of the vee in-line with the centre of rotation. As this was something I had not come across in the course of writing the article I thought it would be wise to make this problem known. When the "query" jig was set at 59 degrees the amount to remove was 13 mm, which is far too much. The amount to be removed should be no more than about 3 mm, I have attached a photograph showing the amount removed from my own jig.
When the "query" jig was reset to 49 degrees the end of the vee was near enough in-line with the axis rotation not to worry about. Upon closer inspection of this jig, the drill angle scale was found to be off-set on the die casting compared to the "clone" that I have. It is this off-set that I believe is the problem. It does however mean the base will need a different angle on the wedge in order to re-establish the correct drill point angle.
I must thank Art for bringing this to my attention.
My best regards
Gray,
