Author Topic: K-27? lets hope so  (Read 13072 times)
Offline bernienufc
  • Northumberland UK
Re: K-27? lets hope so
« Reply #45 on: September 25, 2026, 09:04:56 pm »
I'd like some sort of pointer here if possible please, we are talking about the cranks here.
As my lathe is not up to doing the level of work required without a lot of struggle and a friend has offered to use his biggy lathe for us to do them.
My original plan was to follow the book using the mill for most of the work once i got them faced down to thickness but the friend has said we could do most of the cutting and reaming in one go if i wanted.
Is there a reason for me to follow the book or just getting on the biggy and doing most of it there?
cheers malc
A USA K-27 in the UK, now this should be interesting
« Reply #46 on: September 28, 2026, 07:33:51 pm »
Sorry for the late reply, I was out all weekend. :)
I'm not certain what part you're referring to, I looked through the book quickly and didn't see anything called a crank, though I'm sure it could refer to several different parts.  Regardless, I'd say make the part the way that makes sense to you.  I don't see any reason you have to use Kozo's methods.  I deviated from his methods many times.  He documents a good way to do it, if you have equipment similar to his.  But since you have access to different tools, a different method may work great for you. So, go for it! :)
How's that for wishy-washy advice?  :Lol:
Offline internal_fire
  • Punta Gorda, FL
« Reply #47 on: September 28, 2026, 08:57:03 pm »
There are only two items that are critical on the cranks. Namely the size and position of the two holes, axle and crankpin. Everything else is essentially cosmetic.
The entire crank is less than 4" in extent, so it should be possible to machine it on the equipment found in most home shops.
If you want to use the "biggy" lathe of course that is completely up to you.  :)
Gene
Offline bernienufc
  • Northumberland UK
« Reply #48 on: September 28, 2026, 09:21:28 pm »
It certainly works for me :-D thank you
Offline bernienufc
  • Northumberland UK
« Reply #49 on: September 28, 2026, 09:23:52 pm »
Gene
Thank you gene
Today i had a chat with an engineer who looked it over and said i would be better using the mill and rotary table but did agree that most of it was cosmetic except for the holes as you mention
Offline bernienufc
  • Northumberland UK
« Reply #50 on: October 08, 2026, 06:28:54 pm »
If i ever do another loco i am going to do a 0-4-0 or an 0-2-0 if there is one  :ROFL:
« Reply #51 on: October 08, 2026, 07:00:27 pm »
I'd LOVE to see an 0-2-0!   :lolb:   There must be one designed by Wile E Coyote...
Offline bernienufc
  • Northumberland UK
« Reply #52 on: October 08, 2026, 08:00:43 pm »
:-D
« Reply #53 on: October 08, 2026, 08:29:26 pm »
Just fyi there were / are a couple of real steam locomotives classed as 0-3-0, one used on a monorail system called "Lartigue" in Ireland, and also a similar system in India. Some pics are available in Google if you search for "0-3-0 locomotive".
I see you already found the pic of "Tippy" the 0-2-0... :Lol:
Offline bernienufc
  • Northumberland UK
« Reply #54 on: October 08, 2026, 08:48:51 pm »
I hadn't even realised until after i posted, and after seeing 'tippy' maybe a unicycle   :Lol:
Everyday a school day
Offline uuu
« Reply #55 on: October 09, 2026, 08:04:27 am »
Offline bernienufc
  • Northumberland UK
« Reply #56 on: October 09, 2026, 09:25:22 am »
« Reply #57 on: October 09, 2026, 07:36:42 pm »
Just a suggestion if you build the light blue 0-3-0 - you may need a slightly taller smokestack / chimney to get a good draft for the fire... :Lol:   :cheers:
Offline uuu
« Reply #58 on: October 10, 2026, 07:21:16 am »
It really is a curious loco - the firehole is in the side of the boiler.  See it in action here:
<a href="https://www.youtube.com/watch?v=ilBsu3vrVQY" target="_blank">http://www.youtube.com/watch?v=ilBsu3vrVQY</a>
Wilf
Offline Sanjay F
« Reply #59 on: October 10, 2026, 08:08:35 am »
Is that guy assisting the wheel with a crowbar at 4:09???  :o
