..but a locomotive works too.
Kozo does all his drawings pen/ink by hand, not with CAD, so perhaps his dimensions did not calculate out as precisely?
When I look at the drawing in the book, he doesn't seem to specify the radius of those back rounded corners - the ones you show as R2. He defines the radius of the front round part of the opening as 2R (which matches your 4D). But the back corners of the tranigle-ish cutout aren't defined in Kozo's drawing.So you might be trying to overconstrain it? Just a thought.Kim
If i change the radius of the 2 rear circles surely the straight lines that join them would not be parallel i.e the 4mm offset if that makes sense.
Quote from: bernienufc on May 03, 2026, 06:18:12 pmIf i change the radius of the 2 rear circles surely the straight lines that join them would not be parallel i.e the 4mm offset if that makes sense.Not correct - the lines could still be parallel but the 4mm distance could change so the lines go tangent to the left circle. Does the book show the 4mm distance? Hard to diagnose without having the picture from the book...Is that 4mm circle supposed to be tangent to the 22mm distance you have it at, or centered on it?
