Author Topic: 2" Minnie Traction Engine  (Read 53999 times)
Offline packmule
Re: 2" Minnie Traction Engine
« Reply #60 on: June 25, 2026, 04:51:42 pm »
Thanks for advice Jason :cheers:
Offline packmule
« Reply #61 on: September 22, 2026, 01:44:29 pm »
Hi all,
         still here ploding away at my minnie. i've been busy making some of the smaller parts to try to get ready for a steam test. All parts are as per the book and I encountered no problems. I have changed the damper slightly in that  I've done away with all the bending on the rod as shown in the book and soldered a small rod on the door with a extentsion to go direct to the hornplate using a straight rod and fitted two small caps the the end od the hinge.
« Reply #62 on: September 22, 2026, 10:57:16 pm »
Offline packmule
« Reply #63 on: September 28, 2026, 03:07:33 pm »
 Hi everyone,
I've been looking at the standoff's for the water gauge and would value your opinions. If i double up from the drawing they become 3/4" thick  :???:This seems to me to be way too much. What would you suggest ?
Cheers Bob
« Reply #64 on: September 28, 2026, 04:34:13 pm »
If you are talking about the top and bottom fittings then doubling it all up will be a bit much. I'd go with 6mm glass and proportion everything to suit that, so 1/2" or 9/16" at the flange where they screw in, depending on what size thread you went with in the boiler as you want some area for a flat copper washer.
Offline packmule
« Reply #65 on: September 29, 2026, 09:12:34 am »
Thanks for your reply Jason.
that would make more sense instead of a big chunk sticking out of the backhead. I think this is the first part Ive come across where doubling up look completely out of proportion.
