If you are hesitating to make a conventional crankshaft because of concerns about the complication of the conrods consider using your normal conrods, assemble to the crank pins and then make up the crankshaft in the normal build up process. Loctite 638 will hold it all together with no need for pins. If it is a fail put the blow torch on it, disassemble and recycle the parts.
Andrew
