I suggest trying with one of your existing engines, try to turn it over by pushing/pulling the valve rod.Andrew
If you can lengthen the stroke of the cam version, that would give it more leverage while keeping the simplicity of construction.
I would worry less about the friction and more about the lever arm. At mid stroke, the force would be centered halfway out the cam, rather than out where the crank pin would have been. Much less torque transfer.
Quote from: crueby on June 26, 2026, 01:46:42 pmI would worry less about the friction and more about the lever arm. At mid stroke, the force would be centered halfway out the cam, rather than out where the crank pin would have been. Much less torque transfer.Oh, good grief. For the same stroke S, the lever arm is exactly the same S/2, whatever the diameter of the crankpin.But compare the moment arm about the crankshaft at which the frictional resistance acts between pin an big end with the moment arm in the case of the eccentric and bigger end.
Wrong, Charlie Brown (good grief pun). The lever arm is at the middle of the crankpin. With the pin size in the normal crankshaft design range, its a very small difference. But, for the way this one is drawn, its a huge difference. Look at the picture in reply 12 again!
Quote from: crueby on June 26, 2026, 08:59:12 pmWrong, Charlie Brown (good grief pun). The lever arm is at the middle of the crankpin. With the pin size in the normal crankshaft design range, its a very small difference. But, for the way this one is drawn, its a huge difference. Look at the picture in reply 12 again!You missed the part about the same stroke. (Of course the proposal that started this tangent did not have the same stroke for the two styles.)Gene
Gene, I have read the whole thread again, and I have still missed anything about two styles, let alone with different strokes.Chris, here is a diagram. The lever length for the same stroke is the same in both cases. You are right that it will not work the same, but that is because of the radius at which the friction acts. Hint: imagine with a plain bearing and then with a needle roller.
