Author Topic: Stevens's Marine Screw Engine Recreated  (Read 773 times)
Online Sanjay F
Re: Stevens's Marine Screw Engine Recreated
« Reply #15 on: May 27, 2026, 07:54:11 pm »
Mine is a round peg in a square hole!  :Lol: and mine does have the rocking motion you described, I did wonder what caused that
« Last Edit: May 27, 2026, 08:06:51 pm by Sanjay F »
« Reply #16 on: May 27, 2026, 08:01:35 pm »
 :D Must be lateral forces with nowhere to go ending up causing rotation (or something like that!).
« Reply #17 on: May 27, 2026, 08:36:45 pm »
Nothing I can see with the naked eye. I'll video it tomorrow but compared to Sanjay's there are very small gaps (approx 0.1mm) between crank disc and the screw head to the Scotchyoke so it can't wobble even if it wanted to.
« Reply #18 on: May 28, 2026, 03:49:56 pm »
Not much play to be seen
<a href="https://www.youtube.com/watch?v=cWJWjgOQFTE" target="_blank">http://www.youtube.com/watch?v=cWJWjgOQFTE</a>
« Reply #19 on: May 29, 2026, 04:06:41 pm »
Ah, I see you've got a bearing surface on the crank pink under the yoke and the screw above which is why you're wobble-free  ;D
