Author Topic: Stevens's Marine Screw Engine Recreated  (Read 767 times)
« on: May 25, 2026, 06:11:28 pm »
This one can be firmly blamed on Sanjay as a few months ago he posted about the restoration of an original Stevens's Model Dockyard "Direct Acting Marine Screw Engine" which caught my eye. I do have a reprint of their 1919 catalogue but the image of the engine is not really clear enough to see what is going on but his photos were enough for me to have a go at recreating one of these engines. I went for the No1 size which at 3/4 x 3/4 or in my case 19mm x 19mm is a similar cylinder size to the Stuart "10" range.
As usual I drew it up in metric using Alibre with the intention to use a 3D aluminium print for the main frame with the rest cut from solid.
There was not much to do to the 3D printed frame as I included most of the holes in the file that was sent for printing. I just had to open up and ream the hole for the crankshaft bushes and mill off a small machining allowance on the foot and valve chest "cover"
The main bearings were turned from bronze and the reamed hole used to gauge their size.
The cylinder was roughed out from some cast iron bar
Before finishing the decorative bead with a form tool
A flat section was milled to accept the separate port block
All the holes and passages were machined into the port block prior to bonding into place with JB Weld
The valve chest was just turning and milling from a rectangle of cast iron
Valve milled from a bit of bronze block
Re: Stevens's Marine Screw Engine Recreated
« Reply #1 on: May 25, 2026, 06:14:33 pm »
The eccentric strap was machined from some flat brass repurposed from a shower door hinge
The outside was mostly done with the rotary table before the vice to finish off the lug for the clevis.
I did not take any other construction photos as it is all much the same as other engines. Trial assembly ready for a quick test run..
Online Sanjay F
« Reply #2 on: May 25, 2026, 06:51:48 pm »
How wonderful, it looks gorgeous and I was wondering when you were going to make it as I remember you getting the frame 3d printed. The finish on the frame is fantastic, looks the part with the grainy texture
I definitely think its one of the more interesting and unusual engines; there are so many similar looking engines in these old catalogues by the various manufacturers of the period, but this one sticks out.
An amazing job as usual and really demonstrates what you state about being able to construct things from scratch .........I'll get there one day ........... ;) :popcorn: :ThumbsUp:
« Reply #3 on: May 26, 2026, 01:53:02 am »
Where did you get the frame printed Jason?
« Reply #4 on: May 26, 2026, 06:54:17 am »
Thanks Sanjay, ye s the "cast" finish is just right and as you say its a bit different from other engines which is part of the appeal.
Steamer, I have had all mt 3D metal printing and some PLA done using Craftcloud. They are base din Germany but give prices from around the world and I tend to opt for ProtoTI in china who are usually the chapest option. It's easy to get a price, just upload an STP etc, choose material and finiah. Make sure you check the part size once uploaded as it may need scaling up or down.
Offline Chipswitheverything
« Reply #5 on: May 26, 2026, 08:13:19 am »
This fine engine is a remarkable demonstration of the way that completely modern technology and capabilities can be combined with design from long ago : and allied also to the familiar and traditional processes of workshop model engineering.  Interesting and impressive in all aspects of the build. Dave
« Reply #6 on: May 26, 2026, 09:38:51 am »
Thanks
It is interesting to see how much more compact height wise the engine is compared with a Stuart 10V, which shows why the Scotch Yoke was used to eliminate the length needed for a trunk guide and conrod. Ideal if you want to get it all below deck or just keep the ctr of mass low in a hull.
Well as you can see from the above image it has now had a coat of paint and been mounted on a small base just to stop the flywheel touching.
Quite happy with how it runs. It is not the easiest engine to set up as the port face is on the cylinder which means you can't set the valve to that as it is not solidly connected to the engine once the valve chest is open. I settled for checking that it had equal movement within the valve chest and did a rough 90 +30deg setting for the eccentric. Just needed one adjustment to that to reduce the lead slightly and off it went.
<a href="https://www.youtube.com/watch?v=JO3-BPAoWqU" target="_blank">http://www.youtube.com/watch?v=JO3-BPAoWqU</a>
Online Sanjay F
« Reply #7 on: May 26, 2026, 09:52:21 am »
Love the colour and and yes, needs a base as it keeps wanting to fall over! Set up was tricky, I had actually given up on this engine as I couldn't set it up blind, but used Jason's technique for roughly setting it up and it worked. It's a powerful little engine given its size and I can see you having to hold it down before it escapes of the bench!  ;D
Online Sanjay F
« Reply #8 on: May 26, 2026, 09:59:39 am »
For a bit of fun, here's a similar photo to the one above, a MkI Stuart 10v next to the Stevens' Marine Screw engine, I think mine is the smaller, baby version for sure!!
« Last Edit: May 26, 2026, 10:04:36 am by Sanjay F »
« Reply #9 on: May 26, 2026, 01:03:18 pm »
Yes that scotch yoke going up and down makes for a "lively" engine. I think yours is the same size, if you raise it up so the crankshafts are level like in my photo there is not much difference.
Offline Krypto
« Reply #10 on: May 27, 2026, 12:32:41 am »
Great build!  The fillister head screws look good on a design of that vintage.
« Reply #11 on: May 27, 2026, 06:54:27 am »
Thanks, I also like the look of them on these engines. Hard to get metric ones so I end up making my own.
« Reply #12 on: May 27, 2026, 09:09:49 am »
 :NotWorthy: Very nice. Did you use a slot drill, end mill or a bit of chain drilling for the yoke?
« Reply #13 on: May 27, 2026, 09:16:16 am »
I drilled the corners 2mm. Then ran a series of 5mm holes along to remove most of the waste and then milled it out with a 3mm cutter which was the smallest I had with 8mm+ long flutes to cut right through. Finished the corners with a file.
I think Sanjay's just had a round pin running in the slot but I added a square bronze block
« Reply #14 on: May 27, 2026, 05:05:53 pm »
Cheers. Does the yoke rock slightly relative to the crank disc? I've made four or five engines with yokes and that happens to all of them and I've never figured out why although it doesn't cause any problems when running. I suppose a guide rod at each end would stop it if necessary or maybe having the square block solves it?
Online Sanjay F
« Reply #15 on: May 27, 2026, 07:54:11 pm »
Mine is a round peg in a square hole!  :Lol: and mine does have the rocking motion you described, I did wonder what caused that
« Last Edit: May 27, 2026, 08:06:51 pm by Sanjay F »
« Reply #16 on: May 27, 2026, 08:01:35 pm »
 :D Must be lateral forces with nowhere to go ending up causing rotation (or something like that!).
« Reply #17 on: May 27, 2026, 08:36:45 pm »
Nothing I can see with the naked eye. I'll video it tomorrow but compared to Sanjay's there are very small gaps (approx 0.1mm) between crank disc and the screw head to the Scotchyoke so it can't wobble even if it wanted to.
« Reply #18 on: May 28, 2026, 03:49:56 pm »
Not much play to be seen
<a href="https://www.youtube.com/watch?v=cWJWjgOQFTE" target="_blank">http://www.youtube.com/watch?v=cWJWjgOQFTE</a>
« Reply #19 on: May 29, 2026, 04:06:41 pm »
Ah, I see you've got a bearing surface on the crank pink under the yoke and the screw above which is why you're wobble-free  ;D
