Quite happy with how it runs. It is not the easiest engine to set up as the port face is on the cylinder which means you can't set the valve to that as it is not solidly connected to the engine once the valve chest is open. I settled for checking that it had equal movement within the valve chest and did a rough 90 +30deg setting for the eccentric. Just needed one adjustment to that to reduce the lead slightly and off it went.
I drilled the corners 2mm. Then ran a series of 5mm holes along to remove most of the waste and then milled it out with a 3mm cutter which was the smallest I had with 8mm+ long flutes to cut right through. Finished the corners with a file.
