Peter, my cantilevered pump design was intended to simplify construction (I think many commercial pumps are of similar design). The gears should be supported by the fluid film between then and the cavity. The bearing on the input shaft needs to be able to take the forces from the driving mechanism.Two piece or three piece is an interesting decision. A two-piece pump design, like mine, makes it easy to keep the cavities and shafts concentric and at the required separation but the face of the cavity can only be as good as you can bore it. A three-piece pump is harder to keep concentric and at the same separation unless the parts are doweled together for the boring operation.
