Author Topic: Twin marine oscillator  (Read 7814 times)
Offline Team ricky
« on: November 18, 2025, 02:50:14 pm »
Hi Chaps,
I’ve wanted to build from scrap stock for a while now !
I thought I would base the engine around the original puffin twin and use some different materials and style , Not sure if it will just be a display or fitted just yet .
The materials used are :
Standard : Cast iron
Flywheel  : Cast iron
Shafts.    : 316 stainless
Cylinders: Cast GM (purchased)
Pistons.  : Bronze 11x5
Base.     : 316 stainless
Bearing block : GM
Crank discs: Silver steel
Bore 11mm stroke 11mm
It should make good power and efficiency :)
Jobs to still do are :
Calculate the piston rod lengths
Calculate and make the big ends
Make GM throttle arm
Make steam fittings
Not too much more to go !
Re: Twin marine oscillator
« Reply #1 on: November 18, 2025, 03:45:26 pm »
An excellent start!   :popcorn: :popcorn:
Online Sanjay F
« Reply #2 on: November 18, 2025, 05:44:33 pm »
Well, that's impressive you look like you're well on the way with it, should hear that rumble into life soon! :popcorn: :ThumbsUp:
Offline CI
« Reply #3 on: November 18, 2025, 11:31:17 pm »
Looks nice !
« Reply #4 on: November 19, 2025, 04:38:09 am »
The motor looks good. A good, robust design. I have a similar motor in my model steamship, and it's very reliable.
Offline Team ricky
« Reply #5 on: April 06, 2026, 05:00:46 pm »
Hi Chaps….
It’s been a little while since I have made time on this project!
The engine is now running well and close to final finishing :)
Without gaskets it runs at 3-5 psi which is encouraging to say the least
I did run the engine partially in on the lathe with the correct shims so to not damage the bearings
All went well so I went straight onto compressed air to keep running in
Now seems well sealed cylinder wise , a little work needed to polish the top of the standard to better seal the throttle arm and I think it’s good to go :)
So just a throttle arm to make as I’ve robbed one from another model lol 😂 and some gaskets …
I have recently found a lovely little o ring internal booring bar that just fits in an 1/8” hole that allows me to insert o rings on the piston rod to bottom cover, this is a bit of a game changer in terms of leaks and friction, It works so much better than graphite yarn !
Offline Team ricky
« Reply #6 on: April 06, 2026, 05:03:38 pm »
Some pics
Offline Team ricky
« Reply #7 on: April 06, 2026, 05:04:42 pm »
Pics
Offline Team ricky
« Reply #8 on: April 06, 2026, 05:08:36 pm »
Ooh  ,
Just forgot to mention the cylinder security to the standard needs a bit of thought…. Currently cable ties holding them in place for testing !
I have ordered a tension spring to go all the way around both cylinder and I was going to mill a slot in the standard to accommodate the spring and hide it somewhat , alternatively a bracket could be used or peg the cylinders and use two springs between each cylinder…..
Not sure yet but that’s the joy I guess :)
« Reply #9 on: April 06, 2026, 05:30:44 pm »
Looking good. A stretched O ring is another option for holding the cylinders.
Online Sanjay F
« Reply #10 on: April 06, 2026, 05:34:52 pm »
Nice engine - looking forward to seeing it running  :popcorn: :ThumbsUp:
« Reply #11 on: April 07, 2026, 11:04:11 am »
Very nice.
I've looked at building this sort of configuration before but was never keen on the methods used to hold the cylinders in place, brackets of some sort being the least worst in appearance to my eye. Another possibility would be uprights at each end of the crankshaft with screws and pads pushing on the outside of the cylinders but I'm sure that wouldn't be everyone's cup of tea!
Offline Team ricky
« Reply #12 on: April 07, 2026, 05:34:49 pm »
Today I milled the slot each side of the standard to accommodate the spring/oring and made the throttle arm/disk on the rotary table, All went well and I installed an oring for testing
Runs a treat just the right amount of pressure on the cylinders
https://youtube.com/shorts/YuYA7sgmCJo?si=Ct-G4ew-7IOn1jne
Online Charles Lamont
« Reply #13 on: April 07, 2026, 06:12:13 pm »
This has made me think about how some means of retaining the cylinders might be built in to the column. Is the porting like this?:
« Reply #14 on: April 07, 2026, 07:45:39 pm »
Tension spring down the pivot with pins to hook over set into a pivot stub on the cylinders
Offline Team ricky
« Reply #15 on: April 08, 2026, 01:36:28 pm »
Hi Charles,
Yes that’s the port layout I used ….
I’m pretty much decided on no bracket  :)
Onto a boiler now I guess ! Here’s a pic of the internal grooving tool , this little tool is amazing and can just sneak into an 1/8” hole which is a common size of piston / valve rods on small engines
Offline Team ricky
« Reply #16 on: April 13, 2026, 04:38:14 pm »
Hers a pic of a second hand not completed Scotch return boiler….
It looks to be wetback but I’ll have a look when it arrives to see if it is or not… most model ones I’ve seen are dry back single pass.
I’ve got a small boiler fully fitted but it’s spirit fired and I’m not too keen on it ! So I’ll take the new fittings I used on that one and build up the Scotch return
It was cheap and obviously comes with the risk the current build is not good but I’ll see , It’s silver soldered so far probably except the smoke box which looks to be soft soldered (no good) Easy fix to de solder that and re-silver solder
Offline Team ricky
« Reply #17 on: April 17, 2026, 04:55:13 pm »
So the boiler arrived no problem 😉
As I expected from the pictures the front head has been tickled with a bit an obvious leaks along the seam, an attempt to braise was made unsuccessfully
I’ve cleaned off the braise, opened up any gaps and picked , soldered and fixed
Next there is a tiny leak in the combustion chamber rear, about the worst place pollution lol 😂
It is tiny and not structural, it actually stopped when a bit of contamination went over it tested on low compressor air, Because it’s dry back as expected I can use the loctite trick to draw a tiny bit into the void ! Bit of luck needed but I have very thin post application loctite which is perfectly suited to this type off job
I did just have another thought… it’s possible to fill the wet side of the back head with rosin flux and solder at the end of the job (post bushes) and heat it in place with the boiler up right… that will certainly caulk the problem too….
« Last Edit: April 17, 2026, 05:10:37 pm by Team ricky »
Offline Team ricky
« Reply #18 on: April 17, 2026, 06:36:28 pm »
This arrangement seems best for the sight glass …
Nice and high and gets a little protection from the smoke box, I’m pretty sure I’ll have to make new holes to suit and blank bush some others I don’t need !
Offline Team ricky
« Reply #19 on: April 17, 2026, 06:36:53 pm »
Pic
Offline Team ricky
« Reply #20 on: April 20, 2026, 01:30:16 pm »
Here’s a pic of some progress ;)
I’ve made a Scotch style steam dome and made some bushes ready to solder in place , I decided to go with the sight glass off to one side, pick up on all the existing holes in the side of the shell to feed the gauge, It will be mounted on 11x11 brasss square stock to help it not getting knocked…!
Offline Team ricky
« Reply #21 on: April 21, 2026, 05:47:36 pm »
Now at the stage where the next silver solder session begins!
I’ll solder up all the bushes and sight glass manifold in one …
Just thinking on the back head leak as to whether opening up the dry back to have a good look and provide servicing access to the tubes …. I’m thinking a hole saw set up in the lathe and fixture the shell to the cross slide ! What could possibly go wrong lol 😂
Offline Team ricky
« Reply #22 on: May 03, 2026, 01:11:24 pm »
Here’s a quick steam test :)
Weather is good so had a run !
Alls good , fairly well sealed and runs sweet in both directions and will run slow too , I think I will mount on a board just to display for now :)
https://youtube.com/shorts/ACl07So0OBM?si=hn89M-s6g4Xf5krT
« Reply #23 on: May 03, 2026, 03:58:20 pm »
Nice  :ThumbsUp: :ThumbsUp:
Weird visual effect near the start of the video makes it look like the left then right cylinder is stationary!
Online Sanjay F
« Reply #24 on: May 03, 2026, 04:04:23 pm »
Looking and running great, I had that weird visual effect on the Stuart oscillator I built where it looks like one cylinder stops too .......  ;D
Offline Team ricky
« Reply #25 on: May 03, 2026, 09:31:55 pm »
Good spot :)
The frame rate of YT  causes that lol 😂
Thanks for the kind remarks gents :)
I’ve enjoyed making this engine and glad it runs well
