Model Engine Maker
Help! => Hints, Tips & Tricks => Topic started by: geoff5269 on September 07, 2021, 09:34:50 AM
When i had to make some tapered columns recently and mount the work between centres i didn't like the fact that the driving dog had so much potential for catching your hand. So i devised a more streamlined method of driving the work, which is just a piece of 1" tubing slipped over the centre point with a cutout for a small dog. I'm sure the pictures explain it all.
Also i used my Boring head to offset one end for the taper and this avoids moving the tail stock. https://www.youtube.com/watch?v=xeozBY21q58
Geoff
Another option is to turn a soft ctr held in the chuck and use the side of a chuck jaw to drive a small dog which is what I mostly do as the MT4 ctr on my lathe is a bit bulky and no risk of chewing it up when work offset.
(https://hosting.photobucket.com/albums/v156/jasonballamy/Engineering/Jowitt%20MkII/.highres/DSC00755_zps2fd0vpyb.jpg)
Those are both really good ideas, Geoff. I think I'll be trying them.
I haven't dona any turning between centres - but I do really like your idea :ThumbsUp:
I like that idea of using a boring head for setting the taper. I've offset the tailstock on my lathe a few times, and then blistered the paint off the walls (and machined away a lot of stock on test bars) trying to get it back to dead-center. Thanks Geoff!
