Author Topic: Learnin' Stirlin' - a peculiar looking Stirling Engine  (Read 452 times)
Re: Learnin' Stirlin' - a peculiar looking Stirling Engine
« Reply #30 on: July 07, 2026, 08:43:37 pm »
I just finished up the alcohol burners for a couple 1/2 size Lake Breeze fans I'm working on, pretty pleased with how they turned out for a first time go at it.
Offline Sanjay F
« Reply #31 on: July 07, 2026, 08:52:41 pm »
Wow, Dave you should be pleased they look incredible; so many skilled people here, with skills I've never even heard of!  :) :popcorn: :ThumbsUp:
« Reply #32 on: July 07, 2026, 08:57:16 pm »
Thanks Sanjay!  :ThumbsUp:
Online Charles Lamont
« Reply #33 on: July 08, 2026, 10:01:51 am »
Another interesting restoration job that seems to be coming on nicely. May I suggest the performance could be improved by fitting some insulation material between the brass flange and the lower steel parts. Something like thick gasket material. This should reduce the amount of heat getting to the water jacket.
Offline Sanjay F
« Reply #34 on: July 08, 2026, 01:04:24 pm »
Sounds like a good idea, I have some thick gasket material, let me take a look :ThumbsUp:
Offline Sanjay F
« Reply #35 on: July 08, 2026, 03:29:28 pm »
Made a bit more progress today, smoothed off the JB Weld repair on the displacer piston, repaired the top connection to the radiator, started reassembly of the bottom half of the engine sealing as I go. My goodness that blue stuff gets everywhere!
I made a thick gasket as suggested. I had one piece of the thick stuff left which was just enough to fit, my gasket punches were having trouble getting through it I think they may be worn
Offline Sanjay F
« Reply #36 on: July 08, 2026, 07:22:32 pm »
Here is the 1st run of engine......woo hoo................. and all was good until I noticed the wetness around the displacer rod again and the engine getting slower and slower!  :(
https://www.youtube.com/shorts/cn3mU1BAiW0
I figured there must be a leak between the water jacket and the displacement cylinder so I dismantled everything and did what I should have done before assembly which was to fill the jacket full of water and watch for leaks ..........I thought I might see a drip here and there, but watch the video below .............it's a torrent!
<a href="https://www.youtube.com/watch?v=F8rkDdD55Ik" target="_blank">http://www.youtube.com/watch?v=F8rkDdD55Ik</a>
On further inspection, I have found the cause of the leak 'there's an 'ole yer pipe, guv!'  :D
Take a look at the picture below where I've circled it, you'll be able to see it. So I mistakenly blamed myself for the water filled displacer whereas it was this hole all along; the only way I can see of repairing it is letting the entire thing dry out in the 'warm' weather and then getting a bit of JB Weld in there and then gently smoothing it out?
Given the engine runs even when water-logged I'm holding out hope that this engine will be runner ......... at some point!  ;D
« Reply #37 on: July 08, 2026, 07:37:49 pm »
Congrats on getting it to run!
If that is the bushing that the displacer rod runs through, you might be able to bore it out and loctite a new bronze bushing in place. don't remove the entire bushing, just maybe half of the diameter.
Offline Sanjay F
« Reply #38 on: July 08, 2026, 08:29:36 pm »
Firstly I'm glad I found the problem, I'm not good with mysteries!
I think I'll see how the JB Weld goes and it that doesn't pan out I'll take it from there and look at boring it out. I think I'd have to drill it out and ream it as there's no way I can see to get it mounted in a chuck for the lathe as the jacket has been soldered on good and proper!
« Last Edit: July 08, 2026, 09:32:31 pm by Sanjay F »
