Author Topic: A vertical steam pump.  (Read 972 times)
Re: A vertical steam pump.
« Reply #45 on: July 07, 2026, 07:47:02 pm »
I’ve finished the connecting rod between the eccentric and the slide valve. I was curious to see if the pump would turn when I pressed the compressed air hose against the inlet. The joint currently uses just a simple M2 screw; that will be changed later. The pump valves are also still missing.
Michae
https://youtube.com/shorts/T8Qknv03bMw?is=euOearGT2D5MOuV5l
The initial test run was performed without seals on the cylinder or stuffing box. The piston does not yet have a piston ring, and the slide valve was only roughly adjusted. Still, I am pleased that the engine turns.
Now, everything is being disassembled, and the iron parts are being painted.
« Last Edit: July 07, 2026, 07:57:22 pm by Michael S. »
« Reply #46 on: July 07, 2026, 08:17:19 pm »
Even without those last parts and the seals, its running very well!!
Online Sanjay F
« Reply #47 on: July 07, 2026, 08:25:30 pm »
It looks gorgeous and runs great without all the seals etc. You've really made something special there, congratulations  :popcorn: :ThumbsUp: :ThumbsUp:
« Reply #48 on: July 08, 2026, 08:19:38 pm »
That's a beauty Michael and what a smooth runner already!  :NotWorthy:
« Reply #49 on: July 09, 2026, 10:26:49 am »
Looking good  :praise2:  :praise2: I've always liked scotch yoke engines  :)  :ThumbsUp:
« Reply #50 on: July 09, 2026, 11:14:40 am »
Thank you, Chris, Sanjay, Paul and Roger.  :cheers:
« Last Edit: July 12, 2026, 06:44:40 pm by Michael S. »
« Reply #51 on: July 12, 2026, 06:42:14 pm »
Some small progress has been made on the steam pump. The parts to be painted are currently with the painter.
While the parts are drying, I’ve fabricated a simple main valve and a T-fitting with a displacement lubricator. All that’s missing now are the valves for the water pump. So, there’s still a bit of work to do.
« Last Edit: July 12, 2026, 06:45:35 pm by Michael S. »
Online Sanjay F
« Reply #52 on: July 12, 2026, 07:57:39 pm »
Its the small details which make the difference and you certainly have them  :popcorn: :ThumbsUp:
« Reply #53 on: July 12, 2026, 07:59:59 pm »
I really like the shapes on the valves.   :ThumbsUp:
« Reply #54 on: July 16, 2026, 08:19:08 pm »
The cylinder sheet is finished—this time made of copper.
Since copper darkens quickly, I used a copper/brass patina solution to help the process along.
