I used 8BA on mine because the 7BA Nuts looked too large and ugly. Apart from the fact that you are going to struggle to get a spanner in to tighten them. On this part I used a clearance hole in the base of both and put a slotted bolt up from under the baseplate, into a nut held in a pair of tweezers and then tighten using a screwdriver from beneath A point to note: The whole model uses only 10BA and 8BAs (or you are going to struggle with over hanging nuts and no one wants to see their nuts hanging in mid air )Jo
I have mostly use undersize nuts
Having under sized nuts on a stud
