Author Topic: A Stuart Williamson build  (Read 28913 times)
Online Sanjay F
Re: A Stuart Williamson build
« Reply #30 on: February 05, 2026, 01:35:48 pm »
Oh ....... I can always put it back in the chuck and remove a couple of thou of the solder; presumably the solder is quite abrasive hence removing it?
« Reply #31 on: February 05, 2026, 02:51:32 pm »
Not really, more a case of getting a smooth surface to run against the bearing and there is a chance that the web was not perfectly true to the shaft when soldered.
Online Sanjay F
« Reply #32 on: February 05, 2026, 03:14:50 pm »
Done - and diameter is now looking pretty good  :)
Online Sanjay F
« Reply #33 on: February 05, 2026, 06:25:44 pm »
I don't want to mess this up at the last minute, what is the best way of holding this in order to mill the radius? I have tried chuck in the rotary table but it was jiggling around too much, maybe I should use the chuck in the 2nd pic to lessen the vibration or should I somehow clamp the piece directly to the table?
Should I mount the RT vertically and mill that way ......tbh I don't know :facepalm2:
« Reply #34 on: February 05, 2026, 06:35:55 pm »
Filing buttons. :)
If you want to mill it then hold say a piece of 1/2" bar vertically in the chuck on your rotary table, long enough that the cankshaft clears the chuck, tap the end 5BA and then screw the web to that.
Online Sanjay F
« Reply #35 on: February 05, 2026, 07:04:56 pm »
I was thinking about buttons but ......
How do I hold the filing button(s) as its the shaft which is behind it. I guess I could make a button with a small thread and tap a hole of the equivalent size in the web?
« Reply #36 on: February 05, 2026, 07:11:49 pm »
For the larger diameter around the shaft. Just take a piece of 1/2" bar about 1/2" long and ream a 1/4" hole through it. Slip onto the shaft then hold the shaft in your bench vice. You will effectively have a one sided single button so just keep most of your file in contact with that.
I'm not really sure why you got the jiggling as I use the rotary table all the time to round over just that type of thing. Hold so you have about 1-2mm clearance between web and the chuck jaws then come in at it from the side at full depth making ever decreasing diameter cuts of 10thou depth rather than down from the top
« Last Edit: February 05, 2026, 07:17:15 pm by Jasonb »
Online Sanjay F
« Reply #37 on: February 05, 2026, 07:17:02 pm »
 ;D - I never though of that! That's sounds like a plan, thanks!
« Reply #38 on: February 05, 2026, 07:17:43 pm »
also see the bit I added
Online Sanjay F
« Reply #39 on: February 06, 2026, 09:22:01 am »
That's interesting I was coming down rather than from the side which may be the issue; I've always struggled with rounding these type of components using a RT so maybe that's the reason.
« Last Edit: February 06, 2026, 10:07:33 am by Sanjay F »
Online Sanjay F
« Reply #40 on: February 06, 2026, 05:12:24 pm »
Steady progress today, made the crank pin and the eccentric and I'm using 7BA grubs instead of making the set screws as suggested
« Reply #41 on: February 06, 2026, 06:07:46 pm »
The crankshaft looks good. You're making good progress 👍.
« Reply #42 on: February 07, 2026, 05:07:14 pm »
I hope your column will turn out as good as what dropped on the mat this morning.
Online Sanjay F
« Reply #43 on: February 07, 2026, 05:10:30 pm »
They look great don't they; the finish of the material looks spot on!
Online Sanjay F
« Reply #44 on: February 07, 2026, 05:26:33 pm »
Made a start on the cylinder today, the bore is 0.625" and the lenghth 1.625"; next will be mark out, then machine the ports and steam pasages
