This will be a short build log, but I thought it might be interesting to document the assembly of a Stuart Machined kit from c. 1978. I bought this on eBay as a casting kit, but on opening the package it turned out to be machined, and was almost certainly purchased as a machined kit; the parts were still wrapped in brown paper sealed with paper tape, and the box was full of vintage shredded office documents.
The obligatory box photo:
And the kit unpacked:
Initial reactions: the crankcase and cylinder casting was really nice, and well machined. The aluminum base not so much, with one of the foot holes visible off-center in the lug, and some minor casting issues. Oddly one of the threaded holes in the crankcase was filled with some kind of hard glue, which I had to dig out with a pick and then chase the threads.
The piston valve shipped inside the valve chest, and was a snug sliding fit. None of the edges had been eased. The value chest was pretty flat on the mating surface, other than a minor ding which filed out.
The flywheel was nicely finished.
The connecting rods were only machined on the working surfaces so looked a little rough, but were a good fit on the crank. The caps had oil grooves cut into them.
The bearing caps were also only machined where necessary. The coupling side had a crosscut which raised a significant bur which had to be filed away to get it to fit, and the drilled holes also had raised edges that needed to be filed down. The bores seemed nicely perpendicular to the mating faces
The valve eccentric shaft was hardened and ground, and a very close fit to the reamed hole in the crank case. The gear was held on with a tapered pin, which had to be removed for assembly.
The banjo is a stamped metal part, and the holes on each end needed to be reamed to size; some straightening was also required. The eccentric end has a phosphor bronze bushing, and the other end a brass bushing.
The crankshaft was again only machined on the bearing surfaces, and the gear seems to be permanently attached (shrink fit?). The crankshaft only has a few thou of runout.
The pistons were well finished, but one needed a few tenths taken off with emery paper to fit in the cylinder bore. The gudgeon pins have copper ends to avoid scuffing the cylinder walls, which is nice.
There’s an extra gear, and an extra taper pin; I’m not sure what they are for. The dipstick (not shown) is a rather poor fit in the hole in the crankcase. There are inlet and exhaust fittings (inlet is 1/4-32). There are two blanking plugs for the drain cock holes.
The bit and bobs:
All fasteners are slot-headed screws.
So that's the kit! In later posts I'll talk about putting it together, and the fit and finish required.
