Author Topic: Hunting an 'Antelope'  (Read 6755 times)
Offline vtsteam
Re: Hunting an 'Antelope'
« Reply #15 on: January 11, 2026, 02:35:07 pm »
HH Groves and other early steam powered airplane engine builders used tubes to a central disk valve on opposed twins and radials.
Offline Sanjay F
« Reply #16 on: January 11, 2026, 05:04:41 pm »
I found this, is this what you mean?
« Reply #17 on: January 11, 2026, 06:11:13 pm »
It is more understandable on the layouts of aero engines as they were often single acting so needed the steam at the head end of the cylinder and opposed & radial engines had the heads a long way a part so cast in passages would not have been practical. This is not really the case with this engine.
Here is another example with the steam going to the heads
https://myersengineworks.com/product/steam-aviation-engine-casting-kit/
Offline vtsteam
« Reply #18 on: January 11, 2026, 11:16:08 pm »
Yup.  :cheers:
