Author Topic: 2.5" Gauge Green Arrow Build  (Read 23007 times)
Offline stevendavis
Re: 2.5" Gauge Green Arrow Build
« Reply #30 on: November 07, 2025, 08:06:54 pm »
New mold printed and prepped for when the weather warms up some.
If you want to see my super power, pull my finger!
Offline Zephyrin
  • near Paris, France
« Reply #31 on: November 08, 2025, 09:23:37 am »
the point with the 3d printed parts as models for casting is that I had to increase the size at the slicer, ( 103 % for alu & 105% for Zinc alloys) to cope with the metal retraction...as I don't like to modify the drawings.
Offline stevendavis
« Reply #32 on: November 08, 2025, 03:26:30 pm »
Thanks Zephyrin.
I'll make sure to keep that in mind. The cylinders are oversize for machining; I just messed up on the first mold.
Offline stevendavis
« Reply #33 on: November 17, 2025, 12:17:15 am »
Tried a 3rd pour and it did not work out. I used petrobond for the 1st time and just didn't get it right. So I started machining the cylinders that I had with the original parts. So far so good. Used a tailstock mandrel to set the cylinder in the keets fixture.
« Last Edit: November 17, 2025, 12:29:11 am by stevendavis »
Offline stevendavis
« Reply #34 on: November 17, 2025, 12:23:03 am »
Clean bores on both cylinders!
Offline stevendavis
« Reply #35 on: November 18, 2025, 03:47:53 pm »
Did some initial machining on one of the steam chests I pourd and I believe I'll be able to use them.
« Reply #36 on: November 18, 2025, 05:47:20 pm »
They sure look nice!   :ThumbsUp: :popcorn:
Offline stevendavis
« Reply #37 on: November 19, 2025, 03:32:12 pm »
Thanks Kim,
Been following you on the clock build. Great work by the way!!
Offline stevendavis
« Reply #38 on: November 29, 2025, 06:20:18 pm »
Got some work done on the valve chests over the week.
« Last Edit: November 29, 2025, 06:28:03 pm by stevendavis »
Offline stevendavis
« Reply #39 on: November 29, 2025, 06:23:55 pm »
A couple more. I used a 3/8 four flute on the mill, after pre-drilling with a 7/32 and 1/2, for the procedure.
« Reply #40 on: November 29, 2025, 07:07:14 pm »
Good to see progress  :ThumbsUp:
Per      :cheers:         :popcorn:
Offline stevendavis
« Reply #41 on: November 29, 2025, 11:18:34 pm »
Thanks! Hope I can get a little in each week.
Offline stevendavis
« Reply #42 on: December 02, 2025, 03:27:30 pm »
Got all the glan nuts done for the valve chests.
Offline stevendavis
« Reply #43 on: December 15, 2025, 05:45:54 pm »
Got a little more done last week. Finished the steam passeges in the outside cylinders. I also got the lids and valve spindles made up. Made some blanks for the valves, but haven't finished them up yet. I pickeled one of the cylinders to clean it up, but it turned it a different collor. I'll probably do the other one so they match up, but it's probably not that important, as they will be painted down the road.
« Last Edit: December 15, 2025, 05:51:59 pm by stevendavis »
Offline stevendavis
« Reply #44 on: January 05, 2026, 02:39:44 am »
Spent some time over the holiday to get the caps machined. I didn't have a casting for the driving side, so I machined a couple up from round stock on the rotory table. The others end was machined up from a couple of PM Research castings.
