Perfect Willy, now I understand how to use it. A useful tool Hi "M" thanks for that and I have now made a proper bracket for it ... Also I don't need to put the square on the other side if I put a length of bar in the tool hole at centre height and scribe a lineal the way across the cylinder covers ?!!Willy
The LP cylinder works at a lower pressure, so a wider bolt spacing makes sense? Hi , Ok thanks yes i suppose so !! twas just thinking about the mimetic juxtaposition that i was involved with when i was at art?ART school making sculptures ??!!! Also it reduces the weight of the finished engine !Willy
Good progress and some tricky alignment to come Yes, However there is a lot of metal on the castings so with a few specially manufactured Jigs/Clamps they should all come out reasonably accurate , I have been fettling them first using the saw and my 14" Bastard file and I also collect all the filings for the scrap metal chap ... Willy
