The red and green markings suggest that the engine will be installed with the HP cylinder abaft?yes , very observant of you !!! hopefully the fitters will also be sailors !!Willy
the IP and the LP covers have 14 bolting heads that is quite difficult to divide by 360 degrees
Quote from: steam guy willy on January 23, 2025, 08:11:48 pmthe IP and the LP covers have 14 bolting heads that is quite difficult to divide by 360 degreesI know about "rivet counters". Are there also "bolt counters?" The original engine reportedly used by Bolton as the basis for his design had 16 bolts for the LP cylinder head. There are a few photos floating around of the Australian ferry engine that Bolton modeled. Hi Gene yes thanks for that and I suppose that the size of the bolt heads is also taken into account ....."W"
That's an interesting pineapple like dividing tool Do you know it's originHi Roger, yes , a car boot sale ?!!!! Actually no , think it was a home made one as there are no markings on it It has 3 to 9 faces on it !Cheers
To position the case for machining they would have used either a dividing head or a rotary table, I would think. In mass production, they may have had a bespoke positioning setup too? Thanks , so on CNC equipment are there buttons to divide the 360 degrees by 7 or 9 to rotate the part accurately ? I have never used CNC myself ...I do have a DRO and VRO (Visual Read Out )..to obtain accuracy mostly !!"W"
Quote from: crueby on January 31, 2025, 03:34:18 pmTo position the case for machining they would have used either a dividing head or a rotary table, I would think. In mass production, they may have had a bespoke positioning setup too? Thanks , so on CNC equipment are there buttons to divide the 360 degrees by 7 or 9 to rotate the part accurately ? I have never used CNC myself ...I do have a DRO and VRO (Visual Read Out )..to obtain accuracy mostly !!"W"
