Author Topic: Model Engineer Beam Engine - Reeves Kit  (Read 30920 times)
Re: Model Engineer Beam Engine - Reeves Kit
« Reply #15 on: November 23, 2024, 08:02:19 pm »
Sorry 21 seconds into the video I realised how long this video is and the glass of wine won out :wine1:
If you have a question you need answering you need to make it quickly clear so we can answer it.
Online Jasonb
« Reply #16 on: November 23, 2024, 08:14:59 pm »
can't you multi-task? :LittleDevil:
Offline propforward
  • MN, USA
    • Stuart's Shednanigans
« Reply #17 on: November 23, 2024, 08:16:58 pm »
I don’t have any questions. I’m documenting what I’m doing in the videos, that’s all.
Stuart - "He Meant Well"
« Reply #18 on: November 23, 2024, 08:30:07 pm »
Ask my ex husband   :-X He's the one still working and I'm the one who is :old: into my 7th year of retirement and struggling with the financial challenges   :wine1:
Sorry for the side track Stuart   :-[
« Last Edit: November 23, 2024, 08:35:44 pm by Jo »
Offline propforward
  • MN, USA
« Reply #19 on: November 23, 2024, 09:21:52 pm »
That’s quite alright. A little sidetrack brings some interest and humanity. Otherwise it’s nothing but engines, engines, engines and splitting hairs over a fraction of a thousandth of an inch.
Offline propforward
  • MN, USA
« Reply #20 on: December 24, 2024, 11:29:27 am »
I got time to drill holes. If you want you can watch the process here. It’s just drilling holes. I’ve been kept from machining somewhat by freelance engineering so this is all I got to do for the last month.
Bonus! Shedland Christmas light show spectacular!
I will post still images later. But - it’s just holes drilled and tapped.
<a href="https://www.youtube.com/watch?v=6P0m_uZx2Jo" target="_blank">http://www.youtube.com/watch?v=6P0m_uZx2Jo</a>
Offline propforward
  • MN, USA
« Reply #21 on: December 24, 2024, 01:20:26 pm »
Not much to it really. I did a minimum clean up of the main bearing mounting surface and also the pump mounting surface. the plans don't call for that but I want those surfaces parallel to the other machined surfaces, so that all the final engine components play nicely together.
With that done I mounted a drill chuck - a cheap (it wasn't that cheap) and nasty import chuck which had loads of run out in it - fixed by clamping the jaws of the chuck to a nice piece of drill rod in the lathe and then turning the shank lightly - and installed a center drill and went around my ordinate dimensions and pecked every drill location. That was simply to look at the pattern and see if it was centered well enough on the casting.
I didn't take a pic of the pattern.  :facepalm:
I was happy enough with it - it looks well located overall. The patterns on the round boss are shifted relative to the boss center by about .015 in the X and .020 in the Y, which is easy to see by eye. I think this boss will be completely covered in assembly and not noticeable. If it is noticeable I may put the casting on my rotary table and lightly skim the diameter just to true it up.
Then, happy with that, I went around and drilled and tapped.
Followed up by dusting off the outside edges of the base to make them straight and clean. I also cleaned the flash out of the openings in the base. Did all that by eye and by feel just to get the ugly off, as Joe Pie says.
And that's that for the time being.
I have a little hand fettling to do yet. I chose not to do the base mounting holes quite yet as I have not decided on the final presentation - although really what else am I going to do other than bolt it down through those bosses? Need to hand fettle them round first where I had to cut into them. Or maybe mill them off altogether all the way round - hence not worrying about drilling them quite yet.
« Reply #22 on: December 24, 2024, 03:20:52 pm »
Hello Stuart,
You did a perfect job with the base plate.
I would only drill the mounting holes into these cast elevations. Maybe mill a round surface with the milling cutter.
It's like that with large castings.
« Reply #23 on: December 24, 2024, 05:07:10 pm »
Great to see some progress on your beam engine!  :ThumbsUp: :popcorn:
« Reply #24 on: December 24, 2024, 05:20:40 pm »
Nice work, there is a lot going on there.
Offline propforward
  • MN, USA
« Reply #25 on: December 24, 2024, 08:10:01 pm »
Thank you all. Not much there yet, but precision on this piece is certainly going to be important as more of it comes together. Even just drilling a lot of holes is great fun but I’m looking forward to more ornate looking parts.
Not sure what to tackle next, but need to wrap up this freelance thing first.
Offline scc
  • Lancashire, UK
« Reply #26 on: December 24, 2024, 08:45:29 pm »
Nice work :ThumbsUp:            Terry
Offline MJM460
« Reply #27 on: December 26, 2024, 07:29:59 am »
That base plate is coming on nicely Stuart.  Enjoying every instalment.
« Reply #28 on: December 26, 2024, 08:32:50 am »
Coming along nicely  :ThumbsUp:  :ThumbsUp:
Offline propforward
  • MN, USA
« Reply #29 on: April 19, 2025, 10:43:36 pm »
I made a thing.
I had some communications with a writer at Model Engineer, and was discussing the shortcomings of the base casting on this model. In the end, rather than wait until later, I went ahead and completely removed the circular boss and the two rails next to it. Those features are way off center and will look horrible if left in place.
As a result, I needed to either make the boss as a new disc on its own - or do as I ended up doing and incorporate the disc into the outboard head.
The head is a circular wedge shaped item - you can see it here in cross section, at the bottom of the cylinder.
I made mine like this, to replace the boss at the same time.
Before I go any further, I want to make it clear that the approach I have taken is one of achieving best accuracy I can, because I felt like it. The wedge feature can be achieved by simple marking out perfectly well - in fact I'm sure the engine would run fine if the head was just made with a flat, non angled face. I just decided to go this route because I find it satisfying.
So first off a piece of 2" steel rod went into the lathe. 2" is the largest diameter I can fit through the chuck and spindle, but that's pretty good - saved me having to saw off a lump and make more scrap. That was turned to a top hat shape at final OD of the part that fits in the cylinder - at .0005" under the nominal diameter of the mating bore (when I get to that).
Incidentally - and this is a bit extravagant but REALLY nice - the domestic authority desired a new TV in the house so I repurposed the "old" one as a monitor. It is in full view of lathe and mill. I didn't really think it would work out so well but it is unbelievably nice to have drawings magnified right there in view.
So then that was parted off, turned around and the dowel hole put in the back side.
And there is the top hat - all very simple. A fun bit of turning.
The next bit is the more interesting bit. But I have to take the dog for a walk first.
