Author Topic: Chris's Diesbar Engine Build  (Read 32945 times)
« Reply #630 on: August 22, 2026, 12:39:08 am »
You guys are too much....I just took a Gravol pill.....haven't been this dizzy since I tried log rolling....  :insane: :Lol:
Offline wagnmkr
  • Lindsay, Ontario, Canada
« Reply #631 on: August 22, 2026, 12:14:11 pm »
That's better!!
« Reply #632 on: August 22, 2026, 03:52:19 pm »
The bracket top sections have been made, and just gave the braackets a coat of paint. Not cured up enough to install yet, so I went ahead and wrapped the pipes in some linen tape (made for framing paintings, very handy tape, pretty thick, made of actual linen cloth) to simulate the old insulation style.
While waiting on the paint to harden, I'll make up the lever arms for the valves. The levers need to go on before the valves are assembled onto the engine anyway, or putting on the retaining nuts will be difficult. Once all is assembled, and the sealant for the pieces that go into the trunnions is dry, it will be possible to apply some compressed air and start timing the valves on the cylinders! Should be able to start the timing tomorrow, though we are out at the pond with the boats again, so it won't be till later in the day. Very close!!   :cartwheel:
« Reply #633 on: August 22, 2026, 06:41:31 pm »
Throttle valve levers are made. The valve ends of the levers have a rectangular hole to fit over the end of the valve stem, size copied from the levers they came with (ugly stamped metal with red covers).
Tomorrow afternoon I will assemble the valves and see about timing the cylinder valves. With a little luck the valves are close to centered from when the cylidners were assembled, though no doubt they will need some adjustments.
« Reply #634 on: August 22, 2026, 07:02:17 pm »
« Reply #635 on: August 23, 2026, 02:18:20 pm »
Yesterday evening I got the valves/piping assembled onto the engine, and waited to add air pressure till this morning to let the sealant on the trunnion fittings to cure up. Here's how it looks:
So, major milestone time!  I turned on the compressor, set it to low pressure (around 5 psi), opened all the drain valves on the cylinders,  opened one throttle valve at a time, and turned the crank over by hand to check the valve timings. At first, I ignored the eccentric timing, I wanted to see if the valves were properly centered, opening/closing evenly on the up and down strokes. The right cylinder was good as is, the left one needed a few turns of the valve rod to center it since at first it was opening on the up stroke way early, closing late. After making that adjustment, I got the eccentrics timed, and closed up the drain valves. I then got this!!
<a href="https://www.youtube.com/watch?v=xMTWvsQnEbU" target="_blank">http://www.youtube.com/watch?v=xMTWvsQnEbU</a>
 :pinkelephant: :cartwheel: :wine1: :whoohoo:
Running pretty good for half an hour of adjustments!. That was running in Reverse direction. Then moved to forward and opened the drains again to go through same eccentric timing - got that set, but it was sticking in one spot in the rotation. After a while, I spotted the problem - the screw on the end of the post in the valve plate on the left cylinder is too long, and is hitting the rocker lever:
So, I need to pull that post out and trim the screw. Will do that after the pond run this morning (heading off now).
Overall, WooHoo!!
Offline Sanjay F
« Reply #636 on: August 23, 2026, 04:16:47 pm »
Wow - what a truly magnicient build and end result, I'm transfixed by the movement, congratulations!!  :ThumbsUp: :ThumbsUp:
Offline wagnmkr
« Reply #637 on: August 23, 2026, 04:28:01 pm »
Well Done That Man!!!
The movement is lovely for sure.
 :cheers: :DrinkPint: :cheers:
Tom
« Reply #638 on: August 23, 2026, 04:41:41 pm »
 :ThumbsUp: :ThumbsUp: :ThumbsUp: :popcorn: :popcorn: :popcorn: Very smooth running in reverse Chris!  looking and sounding great. :cheers:
Have fun at the pond, enjoy the screw length adjustment when you get back.
« Reply #639 on: August 23, 2026, 06:08:42 pm »
Thanks guys!!  We had a great time at the pond, after lunch I want to get that one screw fixed and see how it runs in forward. More vids later!
« Reply #640 on: August 23, 2026, 07:43:43 pm »
Okay - and there was much rejoicing (to quote an old comedy show, extra points if you can name which one)!   :pinkelephant:
After lunch got the one screw shortened to fix the interference problem when running in forward direction, and did some more timing tweaks to the eccentric stops. Then made this run, starting in reverse and partway through stopping and switching to forward. Not using the release levers yet, need to learn that sequence. Not sure how well it will work without being able to release the cylinder drains and release the pressures on the non-driving cylinder, will find that out later. Running quite well, very happy!
<a href="https://www.youtube.com/watch?v=FzwXG0ZHqvc" target="_blank">http://www.youtube.com/watch?v=FzwXG0ZHqvc</a>
Still need to make the cold water intake pipe/valve for the condenser, make the throttle control levers/brackets, and do a bunch of touch up painting. But, its a runner!   :whoohoo: :whoohoo: :whoohoo:
« Reply #641 on: August 23, 2026, 08:11:21 pm »
Fantastic to see it run and almost sound like it bigger sibling  :praise2:
You should feel very Chuffed  :cheers:
Per      :popcorn:
« Reply #642 on: August 23, 2026, 10:52:26 pm »
 :ThumbsUp: :ThumbsUp: :ThumbsUp: :popcorn: :popcorn: :popcorn: Excellent!  :cheers:  :whoohoo:
« Reply #643 on: August 24, 2026, 04:49:37 am »
Congratulations on this beautiful engine. It runs very well 👍.
Michael  :cheers:
Offline paul gough
  • Paul Gough
« Reply #644 on: August 24, 2026, 07:37:05 am »
IT’S ALIVE!!! What a wonderful thing it is and a master work to boot. Anybody thinking about trying a twin McOnie engine??  Regards, Paul Gough
« Last Edit: August 24, 2026, 07:44:26 am by paul gough »
