Engines > Your Own Design
Sticking Engine M2
hammer:
Thank you I need a little encouragement. Below the state of play. Geoff
Stilldrillin:
Watching quietly, Geoff........
Looking good so far! :ThumbsUp:
David D
Don1966:
That's very interesting Geoff, a cylinder on each side. The gear is what I don't quite understand. Are you powering the gear with the cylinder?
hammer:
Thats right don, the cylinder of brass will become the crank arms. Seperated from the engine, to the left. The large gear in first photo will be fixed to the paddle shaft. The ideal ratio is 3to1 reduction, the gears from my scrap box are a little less. Geoff
hammer:
Crank completed. Note the arm reduced on the inside so the bearing can be incresed. Only 3/32" but every little helps. Geoff
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
