Author Topic: Laser cutter/ engraver  (Read 310 times)
Offline A7er
  • Cornwall, UK
« on: July 30, 2026, 06:44:16 pm »
I'm considering buying a budget laser cutter/engraver and would like to ask other members if they have one or have used one. I will stress that budget is a deciding factor. I will need it to be able to cut acrylic sheet up to 3mm-ish thick, thin wood about the same thickness, and if possible, thin metal. Maybe brass?
Any ideas? The budget is dependant on what the laser can do.
Lee
Re: Laser cutter/ engraver
« Reply #1 on: July 30, 2026, 08:53:35 pm »
You will need a fiber (NdYAG) laser to cut/engrave metal.  A CO2 laser will cut/engrave acrylic, wood, rubber.  You want an exhaust fan for wood/acrylic/rubber.
Offline A7er
  • Cornwall, UK
« Reply #2 on: July 31, 2026, 07:19:41 pm »
Thanks Bent,
Still looking!
Lee
