Engines > From Plans
Dolbeer Steam Donkey (Les Proper Design)
(1/2) > >>
Rledoux313:
Tonight I was able to get my steam donkey project to successfully run on steam!  :cartwheel:
I’ve been working on and off for almost 2 years on this, and have learned much more than I could have hoped for! The plans for this can be found in LSOR 2018 issue 3/4/5, those issues are in the digital library on village press and can be read if you have a subscription.
Here is a video, and some photos. The eagle eyed among you may notice that the photos show the connecting rod attached to the crank with an eccentric, while the video has a crank pin. When I was building the engine and running it on air I bent the crank rod, likely due to the wrong timing and too much air. This caused me to go the route of the eccentric so I could have the third crank bearing. After having trouble getting it to run I got in touch with Les and he advised changing that to a crank pin. That change, along with denatured alcohol in the fuel pan instead of sterno gel was enough to get it running.
http://www.youtube.com/watch?v=V-wdUCY6A44
crueby:
--- Quote from: Rledoux313 on August 31, 2026, 01:30:15 am ---Tonight I was able to get my steam donkey project to successfully run on steam!  :cartwheel:
--- End quote ---
Excellent!!  Great work, runs very well.   :ThumbsUp: :ThumbsUp:
Whats the burner? Alcohol?
Zephyrin:
nice little model, congratulations, and did you also make the crown gear under the large horizontal flywheel ? I'm looking for a way to cut gears like that.
Sanjay F:
Very nice, well done, it looks and runs great!  :ThumbsUp: :ThumbsUp:
Spinner21:
Nicely done, lovely to hear engines actually running on steam.
Navigation
[0] Message Index
[#] Next page
Go to full version
