Engines > Your Own Design
1/4 scale Porsche 917 180 degree V12 Build
<< < (5/184) > >>
steamer:
Ok...I got some time in the shop finally   More crank disk "B"s and I cut the crank pins.    The  pins need to be drilled and finished to length
When I inspected my first crank disk, I found it was out of spec, so I'll need to crank out 1 more tomorrow.
progress!!
Vixen:
More nice bits :ThumbsUp: :ThumbsUp:
Even with the best CNC machines, there can be slight tolerance differences between otherwise identical components. For critical components, like this built-up crankshaft, it can pay to make an additional one or two. You can then chose the very best, the cream of the cream,  for the final assembly.
ozzie46:
--- Quote from: steamer on September 12, 2021, 01:42:16 am ---Ok...I got some time in the shop finally   More crank disk "B"s and I cut the crank pins.    The  pins need to be drilled and finished to length
progress!!
--- End quote ---
Just don't get cranky about it. :facepalm:
steamer:
Yup  made 8   need 6    I have another blank and it's still set up..
Vixen:
--- Quote from: steamer on September 12, 2021, 12:31:25 pm ---Yup  made 8   need 6    I have another blank and it's still set up..
--- End quote ---
Need 6?? I guess that's 6 side A and 6 more side B
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
