Help! > Machines, Tools and Fixtures
RDG Ball-turning attachment
<< < (3/3)
Zephyrin:
For me, using form tools with the lathe is the most pleasing moment of a workshop session...
I have lots of brass blanks for taps or other fittings left over because I always make more than I need.
you also make your own desired and personal profile, and be certain to have all the same parts.
https://photos.app.goo.gl/Wer5KkTknrEZjdxp6
https://photos.app.goo.gl/HCzF5pnjENWHTa9G9
Allen Smithee:
--- Quote from: Jasonb on December 03, 2025, 10:11:07 am ---As the Hemmingway one just mounts in the tool post you can raise and lower the axis just as you would to set a tool on Ctr height. Might need to get a bit inventive if it is offset a lot but just having some additional holes in the body so the clamping block can be positioned further up or down would cover most cases.
--- End quote ---
You can, but only over a limited range. A horizontal axis tool can allow much greater offset and I'm often want to do ogival shapes like this which are easily done with a vertical axis tool but more of a faff to do by raising the toolpost:
So I probably have a use for both options because for most other uses the horizontal axis one is much easier/quicker to set up (especially when mounted in a QCTP holder!).
AS
Navigation
[0] Message Index
[*] Previous page
Go to full version
